setup:
same results on 3.009 and 3.013
wan ethernet cable not connected.
ap mode off for both 2.4 and 5ghz from gl-gui
connect in repeater mode through gl-gui.
luci gui shows 325.0 Mbit/s, 80MHz, VHT-MCS 7, VHT-NSS 1, Short GI
6.0 Mbit/s, 20MHz
acess points were 4 meters away an no other routers on same freqeuncies near me.
have three other different types of routers and cell phone wifi tether. same results.
tried repeater to a 2.4ghz and says it connects 144/mbs and throughput is 9mb/s
went into luci for client station and disabled legacy b rates… same results for both antennas
I have two 750s routers . same results on both so not looking like isolated hardware issue
you are correct. my router was supporting wireless b mode. I since disabled it and i’m getting 300/300 only issue am having is now with the lan when the wwan is up the lan side is only get 4-6mb/s throughput. same when no wwan and using wan only. and same when using wwan wan as i multihomed gateway with wan as default gateway.
