I am using a GL-AXT1800 and would like to be able to assign a different IP to each of the devices connected.
Currently using Mullvad VPN, but ideally would be if I can connect every device to a specific proxy.
Thanks
Thanks
The purpose of the router is to make one connection available to many devices (NAT). Each device is getting an own IP, but only on the LAN side, the WAN side is the routers connection.
Maybe you should set up just an router and the ‘Mullvad VPN’ on each device. So you are able to have an own connection (IP? I am not familiar with Mullvad VPN) for each device.
