Our system info:
GL-X-750 (V2)
Firmware 3.212
OpenWrt 19.07.8
Kernel Version 4.14.241
Could you give the agent ID of AstroRelay and the version info of your device to me, I will check it for you.
cat /etc/glversion
cat /etc/version.date
Device 1
cat /etc/glversion: 3.212
cat /etc/version.date: 2022-04-07 16:35:29
AstroRelay AgentID: 1000001879337561
Device 2
AstroRelay AgentID: 1000001938903084
Thanks
We have checked that it was a bug of expire ssl certificate and it had been fixed.
Thanks for your feedback.
Thanks. The issue has been resolved.
Hi team, this error is back again. Could you please check the ssl certificate?
We have checked your two agents above with SSL certificate are both normal now, could you describe the issues more specifically?
