Hi guys - I’m pretty intrigued by AstroRelay
Some question on AstroRelay and the Data used (1GB for free … for what exactly?):
- Can I remote control (and restart, update, …) my gl.iNet-Router’s settings with AstroRelay?
- Can I also define or change the VPN-profile it is using?
If yes: - If my PC uses the Routers VPN-profile … will his traffic through my gl.iNet-router then be counted away off of the 1GB? …
- Or is the 1GB data just being used while I am communicating remotely with my Router through AstroRelay?
