astrorelay not working on beta6 on ex300 arc is incompatible
Collected errors:
- pkg_hash_fetch_best_installation_candidate: Packages for arc found, but incompatible with the architectures configured
- opkg_install_cmd: Cannot install package arc.
ash: can’t create /etc/astrorelay/arc.cfg: nonexistent directory
ash: /etc/init.d/arc: not found
root@GL-XE300:~#
Johnex
3
AstroRelay is only working on the latest stable. Once 3.201 hits stable and the SDK is updated, a new version will be available.
Just tested the XE300 3.201_beta6 version and it worked well.
STEP 2. Copy the scripts below and paste it onto your SSH session
not working Collected errors:
