Astrowarp issue - Private DNS
I just found a bug on android devices. If you have private DNS activated, the internet exit does not works. Funny enough, intranet IPs works fine (like router IP to access the web gui).
Disabling private DNS, everything works fine and there's internet connectivity
Your feedback is received.
Did you set the DNS address on your phone to a public server like 8.8.8.8?
I just use private dns like one.one.one.one
We have confirmed the problem and will provide an improvement plan.
Sorry, I just had a problem with the test. I tested again on Android using 1.1.1.1 as the DNS server. Although my remote router cannot be accessed through the internal domain name at this time, the Internet exit works normally. Can you provide more details?
Like I said I'm not using just plain DNS, but Private DNS
Search this on android and test some private DNS URL
Here an example from adguard :
Other exemple from cloudflare
I tried adguard and one.one.one.one, but the problem you described did not occur.
Can you send me your astrowarp username privately? I'll do more in-depth troubleshooting.
Ok but I tested with 2 smartphones, Huawei P30 Pro and Samsung Galaxy S10. Both has the same problem.
I want to confirm, if your exit node location supports these private DNS, I know that the use of private DNS is restricted in some regions, such as China.
It's not restrict, And I can use it with wireguard it's strange it's not working with Astrowarp.
@robotluo still waiting a answer. I can't use astrowarp with this bug, it's annoying
Is your problem unable to use the router in your network as an internet exit?
I noticed you have a free network under your username and no internet exit set up.
As I said, yes I'm using a free account. I'm using my android phone as internet exit and everything is working, I can access internet and local IP from Astrowarp... If I don't use a private DNS from Android. If I use any private DNS address in android, I can't access internet only local IP, when Astrowarp is active. Got it?
I got your problem and this issue is known.
We will provide a solution for this problem in the next APP version.
