AstroWarp - Loosing packets between router
In a Site to Site Configuration packets are lost randomly after ICMP Request (ping). Ping to the Cloud Gateway (Netherland) are ok and no packetloss.
I used a free node in the Netherlands for ping tests in Hong Kong, and no packet loss occurred.
What are the router models?
Do you use 4G/5G routers?
Site A is a GL-X3000, but connected in Repeater Mode to a Telekom Modem. 4G or 5G is not in use.
Site B is a GL-MT2500 connected with an Ethernet cable to a Brume-W. The Brume-W in Repeater Mode to a Telekom Modem.
However, another test in the nighttime showed no loss of packet or once 2% packet loss.
In my next scenario i will connect both router directly with an Ethernet Cable to the Telekom Modems and cancel the Repeater Mode.
Look forward to your results.
