AstroWarp Test Guide
AstroWarp is an advanced SD-WAN platform designed to provide seamless remote networking, traffic aggregation, and remote device management. Built specifically for router integration, AstroWarp supports comprehensive device management across entire networks, enabling both upper and lower device control. It leverages multi-link aggregation transmission based on MPTCP to ensure reliable, high-performance connections. With a focus on network-wide management and future support for hardware-level control, AstroWarp offers a more robust and dependable solution for managing devices and maintaining secure, stable networks.
astrowarp_operation
How is it different from products such as TailScale?
  • AstroWarp is designed specifically for router products, supports router upper and lower device management, and focuses on device management in the entire network. TailScale is more suitable for connecting a single device.
  • AstroWarp implements multi-link aggregation transmission based on MPTCP, and pays more attention to connection reliability.
  • AstroWarp will support hardware-level control.
Typical application
Remote Access
Remote Networking
Keep Your Home IP
Aggregation VPN
Current progress
So far, the following features are available for everyone to try:
  • Aggregate VPN: You can use it to achieve a secure and reliable Internet connection. In scenarios such as video conferencing and live broadcasting, you can use it to achieve uninterrupted connection.
  • Remote networking and remote access (no aggregation): You can use it to achieve remote work, remote gaming, or remote file access.
  • keep your home IP: It is equivalent to a special VPN with a server located in your home. In addition to allowing you to access the Internet with confidence, it is also suitable for various IP-restricted scenarios, such as Netflix media player or some IP-based access policies.
  • APP and desktop applications.
Features still under development:
  • Point-to-point intranet penetration.
  • Hardware-level control support.
Feature to be decided
  • Support for remote networking and remote access with traffic aggregation capabilities.
  • Public network service mapping.
Server location
Currently, we have deployed test servers in the following regions.
Europe:
  • Frankfurt
  • Amsterdam (no traffic aggregation)
  • London
North America:
  • New York
  • Dallas
  • Seattle
  • Chicago (no traffic aggregation)
  • Los Angeles
  • Toronto
Asia:
  • Tokyo
Timeline:
V0.6.0 (done)
  • APP and desktop program support.
  • Support for manually adding IP resources.
v1.0.0 (expected on December 31)
  • Support remote networking and remote access with traffic aggregation capabilities.
  • wake on lan.
Router beta version firmware adaptation:
  • X3000, XE3000, MT3000, MT2500, MT6000
  • AX1800, AXT1800 (Delayed, as soon as possible)
  • For other models, we will consider the CPU and hardware resources and support as much as possible.
  • For supported models, you can download the beta version firmware from the Download Center.
Test time and problem feedback:
  • The test time is October 11 to December 30
  • Astrowarp will provide users with a certain range of free services for a long time if conditions permit. During the test time, if you need to try paid services, you can send an email to support@astrowarp.net and indicate that you need to get a 100% discount coupon.
  • We have tried to simplify the use of astrowarp, but it is still very complicated for users. Before testing, you should learn how to quickly start.
  • If you find any problems during the test, you should first refer to the FAQ to try to solve the problem.
  • If the problem cannot be solved, you can reply to this post directly or send an email to support@astrowarp.net to ask for technical help.
Exciting, can't wait to test aggregation with ISPs that block TCP-options header (common issue with MPTCP), and UDP performance.
I just learned that carriers will restrict TCP option, before this, I only know that some UDP will be restricted, and we have done some processing to avoid UDP restricted scenarios, but there is no good way to restrict TCP option.
I recieved an email for testing, joined the discord server, got kicked twice. :frowning:
Email invitation had the temporary mode enabled, fixed with a reinvite, it would be great to resend the mails with updated links.
HI TMASH, this is Joyce from GL.iNet Marketing Team. Pls try this link: GL.iNet
O2 in the UK were known to cause problems for MPTCP, at least I could never get it to behave with openmptcprouter in the past.
That said I briefly tested it with astrowarp and it did seem to be able to utilise it, I've removed it again now though as the performance on my local cellsite is pretty awful performance wise.
