Per some other forum post I have updated to the 4.8.0 beta firmware but there are fewer options to set not more. I don't see a way to override the APN or even go to Manual Settings for LTE. I can't even tell it which SIM to use; the OG firmware had a "flip" button and the beta does not.
Per Cellular Network Troubleshooting Guide.html, there are no module upgrades available.
I do not see any profiles for AT&T and it is not clear to me how to add a profile manually.
The QCM protocol does not seem to be exposed to the underlying Luci GUI so I can't tweak options manually there.
I can scan towers and see AT&T networks, -12 ~ -10 dB RSRQ as we're indoors, but selecting them does not establish a connection and I want to roam not lock to a tower.
It appears to be selecting "resellermht" for the APN but I believe it should be nrbroadband (5G) or broadband (4G).
How can I override this?
