I’ve installed OpenWrt 22.03.0-rc3 on my GL-B2200, and now I want to go back to GL-iNET stock factory firmware to check on something. I’ve downloaded various firmware options from GL.iNet download center but none of them load correctly via uboot.
I can load and boot a replacement OpenWrt image file just fine, but the factory firmware doesn’t boot up, instead the hardware returns back to uboot.
I’m guessing there’s something else that needs resetting (partitions on the flash, perhaps). Any guidance how to do that on the GL-B2200?
I updated uboot from GitHub - gl-inet/uboot-ipq40xx, in case that would make a difference, but nope. I can still uboot-web update to openwrt 22.03.0-rc3 images, but not to gl-inet downloaded images–those fail to start and the router reboots back to uboot.
Any suggestions on how to diagnose what’s going on?
Yes, thanks! That worked just fine. Is this something you can post publicly so others can access it if they need to switch back from OpenWrt firmware to your firmware?
Hi there @lizh - can you email me the file for restoring partition please (lizardus{AT}list.ru) - same situation here, cannot go gack to stock after OpenWRT.
I ultimately uploaded both norplusemmc-ipq40xx-single.img and 3.216 SDK to uboot and ran those. When checking mount points in LuCI, I can see that /dev/mmcblk0p4 (originally mounted as /data with 6.39GB capacity) is not available. What I am doing wrong and how can I revert to the original setup?
