ATX board no appearing on Accessories
Installed the ATX accessory and front works. USB C cable and do hear the confirmation from windows. On the GLKVM site ATX does appear on site. Any solutions for this? I did update the GlNet firmware.
Please try reconfiguring the ATX board by following this guide:
Once you've done that, open the terminal and run the following command:
ls -l /dev/ttyACM*
Then, please share the output with us and export the logs from the KVM console.
Thanks again for your help — we'll take it from there.
Thank you, figured out issue, had to replace the ATX card.
