ATX compatibility with SFF computers?
Has anyone tried installing ATX board in any of the SFF computers? I have a Thinkcenter m70q which I'm intending to send overseas and would love to have it connected with GL-RM1. ATX board is not a deal-breaker for me, but it would be an incredibly huge improvement.
Thanks!
This mini PC doesn't have a PCIe slot, I think it just can't
What about fingerbot? it can press the power on/off key on the case.
Fingerbot — GL.iNet.
Can be a problem, I just tried with my Lenovo M910 and the issue is the pins on the F-Panel connector and plug are closer together than normal ATX, so the cables can’t connect on either end. (a PCI slot is not required, its just use to mount the card).
In this situation. the fingerBot is better choice.
