Hi, I have a Slate Plus being used in repeater mode, connecting to a WireGuard network. The wireguard configuration specifies a DNS server.
In the DNS settings, I am set to “Automatic”, and I see both “DNS From Repeater” and “DNS from WireGuard” entries, but it seems to only query the DNS from Repeater, and queries are never sent to the WireGuard-specified DNS server.
Is there some way to change the prioritization here? Query the WireGuard DNS server first, and then the Repeater DNS? I don’t want to set my DNS servers manually every time I connect and disconnect from my VPN!
See “using name server 4.2.2.1”, which is what’s coming from the upstream provider.
At this point, it doesn’t even show up in the DNS settings!
(image coming next post because I can only post one.)
Please provide your firmware version.
Also, can you share your wireguard configuration? You can hide the key in the configuration file, but keep the DNS related configuration.
I connected wireguard on version 4.2.1, and then tested it using the dnsleaktest website. The router always used the DNS in the wireguard configuration file. I also tested it after the router restarted, and tried to change the DNS configuration repeatedly, always with the same results.
My Wireguard server is my own, at home - when in ‘road warrior’ mode, simple nslookup tests fail to resolve names defined on the other end of my VPN tunnel.
