Autoreconnect captive portal
Hello everyone,
I bought AX1800. It is supposed to be connected to the public WiFi which has only 1 button to press at the captive portal. Time to time the network shows captive portal again and I have to press the button again. Any change to automate it with the router? Thank you in advance
This is very difficult as you need to check the portal, do analysis of the html etc.
thank you very much for the prompt reply. I thought it is something reserved in router for such functionality. I can make html analysis and page parsing/clicking in something else, like python with selenium or c#. i thought it is possible to embed it into the router. So I bought it specifically for this function.
