ax slate toggle button for tor not working
For my slate ax running v4.6.2 when i enable the toggle button for tor, it seems to always enable tor regardless of the button postion. The only way to disable tor is for me to manually go to the ui->vpn->tor and disable it there. But once i reboot, it'll start tor automatically regardless which position the physical toggle button is set to. Pls research and advise.
Rtype
It works well in my side.
  1. Toggle status: Enable
  2. Toggle status: Disable
Please try to change the toggle control other feature (VPN or ADG) to check one more if the toggle button hardware works?
Thanks for helping. I tried with adguard and it behaves the same way. I then did a factory reset and that didn't help either. Seems my toggle is perpetually in the 'on' position. When I try to switch back and forth, I'm not seeing the same log activity that you do in the system logs.
I sent an email to gl-inet about my experience. Hope they'll send out a new replacement.
