Any idea what is the error below?
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] Fatal error received from wcss software!:
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] QC Image Version: QC_IMAGE_VERSION_STRING=WLAN.HK.2.1-01577-QCAHKSWPL_SILICONZ-1.383726.1
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] Image Variant : IMAGE_VARIANT_STRING=6018.wlanfw.evalQ
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] :0 Ucode Asserted:, PHYA param0 :zero, param1 :zero, param2 :zero.
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] Thread ID : 0x00000000 Thread name : Process ID : 0
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] Register:
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] SP : 0x00000000
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] FP : 0x00000000
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] PC : 0x00000000
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] SSR : 0x00000000
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] BADVA : 0x00000000
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] LR : 0x00000000
Mon Jan 31 09:11:03 2022 kern.err kernel: [167420.662856] No stack pointer recorded (or SP is NULL)…stack data not dumped.
Mon Jan 31 09:11:03 2022 kern.info kernel: [167420.707226] subsys-restart: subsystem_restart_dev(): Restart sequence requested for q6v5-wcss, restart_level = RELATED.
Mon Jan 31 09:11:03 2022 kern.warn kernel: [167420.729538] CPU: 1 PID: 66 Comm: irq/28-smp2p Tainted: P 4.4.60 #1
xize11
January 31, 2022, 7:28am
2
Hmm, from what I can tell from the stacktrace it has either an issue to start the wireless driver in flint or it has an issue to boot the driver.
Could I ask a few questions:
what where your last changes before this happened?
what firmware is being used?
did you flash something else than the stock firmware or by the use of a programmer? or did you do a chip replacement with a different size? (From researching it seems the wifi driver can disappear when you flash a different size on a different chip).
Has the ssid valid symbols in the config or do they invalidate, could you test?
I just googled did you do anything related to the country code ?, It might be crashing by this.
I guess it could be that its fixed when you update to a newer version or do full reset?
lizh
January 31, 2022, 10:44am
3
We’ve checked the information. It needs some time.
thanks @lizh
More info:
Using latest firmware as of now, 3.2.0.8.
Everything out of the box, nothing customize, SSID looks good, the router is pretty solid at 3.2.0.7 version.
Maybe just a random crash, but will like to know what is the issue, thanks.
@lizh crash again today, more logs here:
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] Fatal error received from wcss software!:
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] QC Image Version: QC_IMAGE_VERSION_STRING=WLAN.HK.2.1-01577-QCAHKSWPL_SILICONZ-1.383726.1
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] Image Variant : IMAGE_VARIANT_STRING=6018.wlanfw.evalQ
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] :0 Ucode Asserted:, PHYA param0 :zero, param1 :zero, param2 :zero.
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] Thread ID : 0x00000000 Thread name : Process ID : 0
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] Register:
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] SP : 0x00000000
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] FP : 0x00000000
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] PC : 0x00000000
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] SSR : 0x00000000
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] BADVA : 0x00000000
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] LR : 0x00000000
Fri Feb 4 22:01:08 2022 kern.err kernel: [215564.163960] No stack pointer recorded (or SP is NULL)…stack data not dumped.
Fri Feb 4 22:01:08 2022 kern.info kernel: [215564.208347] subsys-restart: subsystem_restart_dev(): Restart sequence requested for q6v5-wcss, restart_level = RELATED.
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.230598] CPU: 1 PID: 66 Comm: irq/28-smp2p Tainted: P 4.4.60 #1
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.241465] Hardware name: Generic DT based system
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.248861] [<80316d90>] (unwind_backtrace) from [<803136e4>] (show_stack+0x10/0x14)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.253627] [<803136e4>] (show_stack) from [<8051797c>] (dump_stack+0x7c/0x9c)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.261732] [<8051797c>] (dump_stack) from [] (ol_ath_ahb_ssr+0x7b8/0x7c8 [qca_ol])
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.268961] [] (ol_ath_ahb_ssr [qca_ol]) from [<8064cfa4>] (cnss_qca8074_notifier_atomic_nb+0x20/0x30)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.277421] [<8064cfa4>] (cnss_qca8074_notifier_atomic_nb) from [<8033ba5c>] (notifier_call_chain+0x40/0x68)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.287748] [<8033ba5c>] (notifier_call_chain) from [<8033bb64>] (__atomic_notifier_call_chain+0x34/0x48)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.297642] [<8033bb64>] (__atomic_notifier_call_chain) from [<8033bb8c>] (atomic_notifier_call_chain+0x14/0x1c)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.307193] [<8033bb8c>] (atomic_notifier_call_chain) from [<8059fe9c>] (notify_each_subsys_device.constprop.4+0x90/0xa8)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.317524] [<8059fe9c>] (notify_each_subsys_device.constprop.4) from [<805a0570>] (subsystem_restart_dev+0x16c/0x274)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.328459] [<805a0570>] (subsystem_restart_dev) from [<806f36b0>] (wcss_err_fatal_intr_handler+0xbc/0xe8)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.339135] [<806f36b0>] (wcss_err_fatal_intr_handler) from [<803619a0>] (handle_nested_irq+0x98/0xe0)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.348856] [<803619a0>] (handle_nested_irq) from [<8057fbbc>] (qcom_smp2p_intr+0x184/0x1dc)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.358231] [<8057fbbc>] (qcom_smp2p_intr) from [<8035fb44>] (irq_thread_fn+0x1c/0x34)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.366909] [<8035fb44>] (irq_thread_fn) from [<8035fde0>] (irq_thread+0xec/0x1c8)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.374719] [<8035fde0>] (irq_thread) from [<8033aea4>] (kthread+0xd8/0xec)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.382358] [<8033aea4>] (kthread) from [<80301c28>] (ret_from_fork+0x14/0x2c)
Fri Feb 4 22:01:08 2022 kern.emerg kernel: [215564.389646] Kernel panic - not syncing: Take care of the TARGET ASSERT first
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.396680] CPU: 1 PID: 66 Comm: irq/28-smp2p Tainted: P 4.4.60 #1
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.405355] Hardware name: Generic DT based system
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.412998] [<80316d90>] (unwind_backtrace) from [<803136e4>] (show_stack+0x10/0x14)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.417776] [<803136e4>] (show_stack) from [<8051797c>] (dump_stack+0x7c/0x9c)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.425763] [<8051797c>] (dump_stack) from [<803234a0>] (panic+0x84/0x1f8)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.432988] [<803234a0>] (panic) from [] (ol_ath_ahb_ssr+0x7c4/0x7c8 [qca_ol])
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.439929] [] (ol_ath_ahb_ssr [qca_ol]) from [<8064cfa4>] (cnss_qca8074_notifier_atomic_nb+0x20/0x30)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.448165] [<8064cfa4>] (cnss_qca8074_notifier_atomic_nb) from [<8033ba5c>] (notifier_call_chain+0x40/0x68)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.458407] [<8033ba5c>] (notifier_call_chain) from [<8033bb64>] (__atomic_notifier_call_chain+0x34/0x48)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.468300] [<8033bb64>] (__atomic_notifier_call_chain) from [<8033bb8c>] (atomic_notifier_call_chain+0x14/0x1c)
Fri Feb 4 22:01:08 2022 kern.warn kernel: [215564.477850] [<8033bb8c>] (atomic_notifier_call_chain) from [<8059fe9c>] (notify_each_subsys_device.constprop.4+0x90/0xa8)
Fri Feb 4 22:01:39 2022 user.emerg : Command failed: Not found
lizh
February 16, 2022, 10:20am
6
You can test it with V3.209.GL.iNet download center
The above problems are caused by USB ports.
cafebug
February 16, 2022, 2:58pm
7
Just upgrade firmware V.3.209 and found out that it will initial the setting to factory default even when you’ve checked the option “keep settings” from UI.
lizh
February 17, 2022, 1:44am
8
Thanks for your feedback, I am doing a lot of stack testing to verify this problem.
alzhao
February 17, 2022, 4:42am
9
It is a bug that happens sometimes. Wait for a fix.
Hi, Jounouchi, the new testing firmware qsdk-ax1800-3.214-0413.img is released to address the crash issue, could you please have a try.
