I have the Wireguard server configured and working properly. Also AdGuard is enabled and working for the internal network.
What else needs to be put in place to use the Wireguard server (10.55.0.1) or the router (192.168.8.1) as DNS for the clients instead of the default 64.6.64.6 option?
I tried that and also 192.168.8.1. It does not work - the client connects and the connection stays alive (i.e. handshakes take place) but no Internet name resolution.
Yes, it does - using 192.168.8.1 as DNS I have access to the internal network (open the router interface in a browser works.) But as I said, no name resolution for the Internet.
I have an Ubuntu box on the network. The dig command works as expected on Ubuntu on the local network. It also works on a Wireguard smartphone client connected over SSH to the internal Ubuntu box.
Just for clarity - 192.168.8.1 works as DNS on the internal network. It does not work though as DNS for a Wireguard client connected to the server running on Flint.
Hmm. It’s not actually clear that the dnsmasq.conf file does anything either. Someone from GL.iNet may have to comment… they may be doing something weird with the config/service in a non-standard way.
Hello good afternoon
For information, I am running a wireguard server on a Flint router with firmware 3.214.
My wireguard clients (Laptop, android smartphone) have a DNS 192.168.8.1 and resolve correctly.
I’m using Flint as the WG server and a laptop and smartphones are the WG clients.
NOTE 1: AdGuard Home is enabled and everything works well on the local network.
The WG clients can use external DNS (i.e. 64.6.64.6, 1.1.1.1 etc) and work well. However, the VPN server IP - 10.55.0.1 or the router 192.168.8.1 do not work as WG DNS on the client side.
Well, the F/W versions are quite different and I’m using AdGuard Home as mentioned in my first post in the thread.
…so there’s not much to compare. However, I’m glad you have it working :).
