AX1800 (Flint) Firmware v4.8.3 - Failed to mount USB drive as rootfs (Extroot) after update
I recently updated my GL-AX1800 (Flint) from firmware version 4.6.8 to 4.8.3. Since the update, I have been unable to mount my USB drive as the root filesystem (Extroot), which was working perfectly on the previous version.
It seems the system fails to recognize or mount the partition during the boot sequence. I have checked the physical connection and the drive appears to be healthy.
Here are the relevant logs from the system:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x51af8014]
[ 0.000000] Linux version 5.4.164 (xinxing@gl-System-Product-Name) (gcc version 12.3.0 (OpenWrt GCC 12.3.0 )) #0 SMP PREEMPT Fri Dec 26 01:07:14 2025
[ 0.000000] Machine model: GL Technologies, Inc. AX1800
[ 0.000000] On node 0 totalpages: 111104
[ 0.000000] DMA32 zone: 1736 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 111104 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 24 pages/cpu s58776 r8192 d31336 u98304
[ 0.000000] pcpu-alloc: s58776 r8192 d31336 u98304 alloc=244096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 109368
[ 0.000000] Kernel command line: console=ttyMSM0,115200n8 ubi.mtd=rootfs root=mtd:ubi_rootfs rootfstype=squashfs rootwait swiotlb=1 coherent_pool=2M ubi.block=0,ubi_rootfs root=/dev/ubiblock0_1
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 413768K/444416K available (7678K kernel code, 590K rwdata, 2420K rodata, 576K init, 369K bss, 30648K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv2m: range[mem 0x0b00a000-0x0b00affc], SPI[448:479]
[ 0.000000] random: get_random_bytes called from start_kernel+0x320/0x46c with crng_init=0
[ 0.000000] arch_timer: cp15 and mmio timer(s) running at 24.00MHz (virt/virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000233] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000244] pid_max: default: 32768 minimum: 301
[ 0.000367] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.000378] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.001619] ASID allocator initialised with 65536 entries
[ 0.001700] rcu: Hierarchical SRCU implementation.
[ 0.003403] smp: Bringing up secondary CPUs ...
[ 0.003947] Detected VIPT I-cache on CPU1
[ 0.003995] CPU1: Booted secondary processor 0x0000000001 [0x51af8014]
[ 0.004561] Detected VIPT I-cache on CPU2
[ 0.004592] CPU2: Booted secondary processor 0x0000000002 [0x51af8014]
[ 0.005098] Detected VIPT I-cache on CPU3
[ 0.005126] CPU3: Booted secondary processor 0x0000000003 [0x51af8014]
[ 0.005192] smp: Brought up 1 node, 4 CPUs
[ 0.005212] SMP: Total of 4 processors activated.
[ 0.005219] CPU features: detected: 32-bit EL0 Support
[ 0.005225] CPU features: detected: CRC32 instructions
[ 0.005265] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.005272] CPU: All CPU(s) started at EL1
[ 0.005532] alternatives: patching kernel code
[ 0.016389] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.016409] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.016556] pinctrl core: initialized pinctrl subsystem
[ 0.017273] NET: Registered protocol family 16
[ 0.017894] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.018286] cpuidle: using governor ladder
[ 0.018309] cpuidle: using governor menu
[ 0.018447] NET: Registered protocol family 42
[ 0.018638] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.021235] printk: console [pstore-1] enabled
[ 0.021299] pstore: Registered ramoops as persistent store backend
[ 0.021308] ramoops: using 0x100000@0x4e400000, ecc: 0
[ 0.071945] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 0.073590] msm_sps_probe: sps:sps is ready
[ 0.080927] cryptd: max_cpu_qlen set to 1000
[ 0.093962] pps_core: LinuxPPS API ver. 1 registered
[ 0.093977] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.093996] PTP clock support registered
[ 0.094647] qcom_glink_rpm rpm-glink: RPM TOC has invalid magic
[ 0.094673] qcom_glink_rpm: probe of rpm-glink failed with error -22
[ 0.095497] clocksource: Switched to clocksource arch_sys_counter
[ 0.095974] thermal_sys: Registered thermal governor 'step_wise'
[ 0.095977] thermal_sys: Registered thermal governor 'user_space'
[ 0.097073] NET: Registered protocol family 2
[ 0.097175] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.097693] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.097717] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.097766] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.097843] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.097918] mptcp init
[ 0.097983] MPTCP token hash table entries: 512 (order: 1, 12288 bytes, linear)
[ 0.098035] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.098060] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.098204] NET: Registered protocol family 1
[ 0.098235] PCI: CLS 0 bytes, default 64
[ 0.098955] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.114313] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.119031] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.119046] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.138774] Key type asymmetric registered
[ 0.138787] Asymmetric key parser 'x509' registered
[ 0.139538] qcom-qmp-phy 78000.ssphy: 78000.ssphy supply vdda-phy not found, using dummy regulator
[ 0.139594] qcom-qmp-phy 78000.ssphy: 78000.ssphy supply vdda-pll not found, using dummy regulator
[ 0.140411] qcom-qmp-phy 78000.ssphy: Registered Qcom-QMP phy
[ 0.140841] qcom-qusb2-phy 79000.qusb: 79000.qusb supply vdda-pll not found, using dummy regulator
[ 0.140887] qcom-qusb2-phy 79000.qusb: 79000.qusb supply vdda-phy-dpdm not found, using dummy regulator
[ 0.140983] qcom-qusb2-phy 79000.qusb: Registered Qcom-QUSB2 phy
[ 0.141298] gpio-export soc:gpio-export: 1 gpio(s) exported
[ 0.144143] bam-dma-engine 704000.dma: num-channels unspecified in dt
[ 0.144154] bam-dma-engine 704000.dma: num-ees unspecified in dt
[ 0.144859] bam-dma-engine 7884000.dma: qcom,controlled-remotely unspecified
[ 0.145863] bam-dma-engine 7984000.dma: qcom,controlled-remotely unspecified
[ 0.146380] msm-dcc b3000.dcc: DCC XPU is not specified
[ 0.146563] msm-dcc b3000.dcc: DCC REG dump setup failed
[ 0.146576] msm-dcc b3000.dcc: DCC SRAM dump setup failed
[ 0.146600] msm-dcc b3000.dcc: jiffies_64: 0xffff8ade, cntvct_64: 0x10414d2b
[ 0.146612] msm-dcc b3000.dcc: gcnt_hi: 0x00000000(0x(ptrval))
[ 0.146622] msm-dcc b3000.dcc: gcnt_lo: 0x10414f57(0x(ptrval))
[ 0.147010] global timer is null
[ 0.147172] CPU: IPQ6000, SoC Version: 1.0
[ 0.147180] OEM_ID: 0, PROD_ID: 0
[ 0.147536] msm_rpm_log_probe: OK
[ 0.148011] TZ SMMU State: SMMU Stage2 Enabled
[ 0.148062] TZ Log : Will warn on Access Violation, as paniconaccessviolation is not set
[ 0.148323] msm_serial 78b1000.serial: msm_serial: detected port
#0*
[ 0.148353] msm_serial 78b1000.serial: uartclk = 1843200
[ 0.148396] 78b1000.serial: ttyMSM0 at MMIO 0x78b1000 (irq = 12, base_baud = 115200) is a MSM
[ 0.148419] msm_serial: console setup on port* #0*
[ 0.864843] printk: console [ttyMSM0] enabled
[ 0.869709] msm_serial: driver initialized
[ 0.874034] random: fast init done
[ 0.877941] random: crng init done
[ 0.883448] brd: module loaded
[ 0.887409] loop: module loaded
[ 0.889014] nand: device found, Manufacturer ID: 0xf8, Chip ID: 0xa1
[ 0.890604] nand: Unknown FMND1G08S3D
[ 0.897221] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 0.900826] 11 fixed-partitions partitions found on MTD device qcom_nand.0
[ 0.908237] Creating 11 MTD partitions on "qcom_nand.0":
[ 0.915084] 0x000000000000-0x000000180000 : "0:SBL1"
[ 0.922443] 0x000000180000-0x000000280000 : "0:MIBIB"
[ 0.926880] 0x000000280000-0x000000600000 : "0:QSEE"
[ 0.934012] 0x000000600000-0x000000680000 : "0:DEVCFG"
[ 0.936415] 0x000000680000-0x000000700000 : "0:RPM"
[ 0.941372] 0x000000700000-0x000000780000 : "0:CDT"
[ 0.946156] 0x000000780000-0x000000800000 : "0:APPSBLENV"
[ 0.951000] 0x000000800000-0x000000980000 : "0:APPSBL"
[ 0.957517] 0x000000980000-0x000000a00000 : "0:ART"
[ 0.961583] 0x000000a00000-0x000007d00000 : "rootfs"
[ 1.073990] mtd: device 9 (rootfs) set to be root filesystem
[ 1.074331] mtdsplit: no squashfs found in "rootfs"
[ 1.078730] 0x000007d00000-0x000007d80000 : "0:ETHPHYFW"
[ 1.085257] libphy: Fixed MDIO Bus: probed
[ 1.309192] qca-mdio 90000.mdio: Could not find phy-reset-gpio
[ 1.309314] libphy: qca_mdio: probed
[ 1.315159] qca-mdio 90000.mdio: qca-mdio driver was registered
[ 1.317787] i2c /dev entries driver
[ 1.328604] sdhci: Secure Digital Host Controller Interface driver
[ 1.328636] sdhci: Copyright(c) Pierre Ossman
[ 1.333668] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.338460]
[ 1.338460] Version Rollback Feature Disabled
[ 1.345841] remoteproc remoteproc0: cd00000.remoteproc is available
[ 1.349896] coresight-tmc 6047000.tmc: failed to get flush cti, defer probe
[ 1.355891] coresight-dynamic-funnel 6041000.funnel: Uses obsolete Coresight DT bindings
[ 1.363778] coresight coresight-etm0: CPU0: ETM v4.0 initialized
[ 1.370969] coresight-etm4x 619c000.etm: CPU0: (null) initialized
[ 1.377192] coresight coresight-etm1: CPU1: ETM v4.0 initialized
[ 1.382896] coresight-etm4x 619d000.etm: CPU1: (null) initialized
[ 1.389256] coresight coresight-etm2: CPU2: ETM v4.0 initialized
[ 1.394960] coresight-etm4x 619e000.etm: CPU2: (null) initialized
[ 1.401324] coresight coresight-etm3: CPU3: ETM v4.0 initialized
[ 1.407041] coresight-etm4x 619f000.etm: CPU3: (null) initialized
[ 1.413269] coresight-stm 6002000.stm: coresight-stm : stm_register_device failed, probing deferred
[ 1.419201] OF: graph: no port node found in /soc/cti@6010000
[ 1.428081] OF: graph: no port node found in /soc/cti@6011000
[ 1.433983] OF: graph: no port node found in /soc/cti@6012000
[ 1.439705] OF: graph: no port node found in /soc/cti@6013000
[ 1.445421] OF: graph: no port node found in /soc/cti@6014000
[ 1.451167] OF: graph: no port node found in /soc/cti@6015000
[ 1.456894] OF: graph: no port node found in /soc/cti@6016000
[ 1.462608] OF: graph: no port node found in /soc/cti@6017000
[ 1.468356] OF: graph: no port node found in /soc/cti@6018000
[ 1.474064] OF: graph: no port node found in /soc/cti@6019000
[ 1.479821] OF: graph: no port node found in /soc/cti@601a000
[ 1.485547] OF: graph: no port node found in /soc/cti@601b000
[ 1.491257] OF: graph: no port node found in /soc/cti@601c000
[ 1.497000] OF: graph: no port node found in /soc/cti@601d000
[ 1.502718] OF: graph: no port node found in /soc/cti@601e000
[ 1.508459] OF: graph: no port node found in /soc/cti@601f000
[ 1.514175] OF: graph: no port node found in /soc/cti@6198000
[ 1.519926] OF: graph: no port node found in /soc/cti@6199000
[ 1.525654] OF: graph: no port node found in /soc/cti@619a000
[ 1.531365] OF: graph: no port node found in /soc/cti@619b000
[ 1.537112] OF: graph: no port node found in /soc/cti@610c000
[ 1.543451] OF: graph: no port node found in /soc/hwevent@6101000
[ 1.548447] coresight-hwevent 6101000.hwevent: No csr data
[ 1.554730] OF: graph: no port node found in /soc/csr@6001000
[ 1.559962] coresight-csr 6001000.csr: CSR initialized: coresight-csr
[ 1.566645] NET: Registered protocol family 10
[ 1.572961] Segment Routing with IPv6
[ 1.576559] NET: Registered protocol family 17
[ 1.580243] Bridge firewalling registered
[ 1.584613] 8021q: 802.1Q VLAN Support v1.8
[ 1.604975] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 1.605982] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 24000 KHz
[ 1.611141] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 864000 KHz
[ 1.618652] sps_register_bam_device: sps:BAM 0x0000000006064000 is registered
[ 1.627544] coresight coresight-stm: STM32 initialized
[ 1.634055] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 1.639265] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 1.646475] ubi0: attaching mtd9
[ 2.271554] ubi0: scanning is finished
[ 2.278827] ubi0: attached mtd9 (name "rootfs", size 115 MiB)
[ 2.278851] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.283543] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.290326] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.297180] ubi0: good PEBs: 920, bad PEBs: 0, corrupted PEBs: 0
[ 2.303940] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
[ 2.310202] ubi0: max/mean erase counter: 49/14, WL threshold: 4096, image sequence number: 1473387677
[ 2.317236] ubi0: available PEBs: 0, total reserved PEBs: 920, PEBs reserved for bad PEB handling: 20
[ 2.326533] ubi0: background thread "ubi_bgt0d" started, PID 157
[ 2.326952] block ubiblock0_1: created from ubi0:1(ubi_rootfs)
[ 2.341885] hctosys: unable to open rtc device (rtc0)
[ 2.350818] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 2.352915] Freeing unused kernel memory: 576K
[ 2.385512] Run /sbin/init as init process
[ 2.592331] init: Console is alive
[ 2.592480] init: - watchdog -
[ 3.760381] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 3.779121] install gl_hw_info
[ 3.779219] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 3.786258] usbcore: registered new interface driver usbfs
[ 3.788296] usbcore: registered new interface driver hub
[ 3.793858] usbcore: registered new device driver usb
[ 3.800980] exfat: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.804977] exFAT: Version 1.3.0
[ 3.819168] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 3.823513] SCSI subsystem initialized
[ 3.831410] mtd-rw: install gl_mtd_rw succeed
[ 3.831529] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 3.835241] usbcore: registered new interface driver usb-storage
[ 3.842875] usbcore: registered new interface driver uas
[ 3.848361] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 3.858358] init: - preinit -
[ 6.571838] mount_root: loading kmods from internal overlay
[ 6.590114] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 6.593741] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 6.697877] UBIFS (ubi0:2): Mounting in unauthenticated mode
[ 6.698006] UBIFS (ubi0:2): background thread "ubifs_bgt0_2" started, PID 274
[ 6.744287] UBIFS (ubi0:2): recovery needed
[ 6.881363] UBIFS (ubi0:2): recovery completed
[ 6.881469] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name "rootfs_data"
[ 6.884732] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 6.892636] UBIFS (ubi0:2): FS size: 46854144 bytes (44 MiB, 369 LEBs), journal size 2285568 bytes (2 MiB, 18 LEBs)
[ 6.902507] UBIFS (ubi0:2): reserved for root: 2213036 bytes (2161 KiB)
[ 6.912743] UBIFS (ubi0:2): media format: w4/r0 (latest is w5/r0), UUID CBB6C63A-139D-4867-8BBE-6C95D56A34F2, small LPT model
[ 6.920708] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 6.936840] block: extroot: device not present, retrying in 25 seconds
[ 31.969488] block: extroot: cannot find device with UUID f58fe1d4-8b06-4f9b-9e94-82336192b557
[ 31.969659] UBIFS (ubi0:2): un-mount UBI device 0
[ 31.977036] UBIFS (ubi0:2): background thread "ubifs_bgt0_2" stops
[ 31.984356] UBIFS (ubi0:2): Mounting in unauthenticated mode
[ 31.987887] UBIFS (ubi0:2): background thread "ubifs_bgt0_2" started, PID 323
[ 32.087670] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name "rootfs_data"
[ 32.087699] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 32.094479] UBIFS (ubi0:2): FS size: 46854144 bytes (44 MiB, 369 LEBs), journal size 2285568 bytes (2 MiB, 18 LEBs)
[ 32.104395] UBIFS (ubi0:2): reserved for root: 2213036 bytes (2161 KiB)
[ 32.114619] UBIFS (ubi0:2): media format: w4/r0 (latest is w5/r0), UUID CBB6C63A-139D-4867-8BBE-6C95D56A34F2, small LPT model
[ 32.127181] mount_root: loading kmods from internal overlay
[ 32.147377] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 32.149082] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 32.190796] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 32.193983] block: extroot: device not present, retrying in 25 seconds
[ 57.228374] block: extroot: cannot find device with UUID f58fe1d4-8b06-4f9b-9e94-82336192b557
[ 57.230804] mount_root: switching to ubifs overlay
[ 57.245597] urandom-seed: Seeding with /etc/urandom.seed
[ 57.415438] procd: - early -
[ 57.415561] procd: - watchdog -
[ 57.951296] procd: - watchdog -
[ 57.953233] procd: - ubus -
[ 58.006745] procd: - init -
[ 58.713369] kmodloader: loading kernel modules from /etc/modules.d/*
[ 58.729543] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 58.730817] DNS Mark module loaded
[ 58.734966] OpenVPN data channel offload (ovpn-dco) 2.0.0 -- (C) 2020- OpenVPN, Inc.
[ 58.830071] ssdk_switch_device_num_init[1306]:INFO:ess-switch dts node number: 1
[ 58.830215] ssdk_dt_get_switch_node[1098]:INFO:ess-switch DT exist!
[ 58.836545] ssdk_dt_parse_access_mode[984]:INFO:switch_access_mode: local bus
[ 58.842519] ssdk_dt_parse_access_mode[997]:INFO:switchreg_base_addr: 0x3a000000
[ 58.849830] ssdk_dt_parse_access_mode[998]:INFO:switchreg_size: 0x1000000
[ 58.855049] urngd: v1.0.2 started.
[ 58.856934] ssdk_dt_parse_mac_mode[313]:INFO:mac mode = 0x0
[ 58.856938] ssdk_dt_parse_mac_mode[322]:INFO:mac mode1 = 0xff
[ 58.856941] ssdk_dt_parse_mac_mode[331]:INFO:mac mode2 = 0xff
[ 58.857003] ssdk_dt_parse_uniphy[350]:INFO:ess-uniphy DT exist!
[ 58.884429] ssdk_dt_parse_intf_mac[927]:INFO:dp1 MAC 94:83:xx:xx:xx:xx
[ 58.890064] ssdk_dt_parse_intf_mac[927]:INFO:dp2 MAC 94:83:xx:xx:xx:xx
[ 58.896919] ssdk_plat_init[1679]:INFO:ssdk_plat_init start
[ 59.016475] ssdk_gcc_clock_init[1220]:INFO:SSDK gcc clock init successfully!
[ 59.016725] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 59.023169] malibu_phy_api_ops_init[2834]:INFO:qca probe malibu phy driver succeeded!
[ 59.033089] regi_init[4000]:INFO:Initializing HPPE!!
[ 59.275498] ssdk_ppe_reset_init[1478]:INFO:ppe reset successfully!
[ 59.278284] qca_hppe_portctrl_hw_init[123]:INFO:Cypress PPE port initializing
[ 59.395889] __adpt_hppe_uniphy_psgmii_mode_set[1049]:INFO:uniphy 0 psgmii channel selection
[ 59.620693] ssdk_switch_register[2008]:INFO:Chip version 0x1501
[ 59.620725] qca_link_polling_select[1488]:INFO:link-polling-required node does not exist
[ 59.625408] ssdk_switch_register[2034]:INFO:polling is selected
[ 59.633753] regi_init[4004]:INFO:Initializing HPPE Done!!
[ 59.639458] ssdk_genl_init[211]:INFO:ssdk genl family register success.
[ 59.644942] regi_init[4067]:INFO:qca-ssdk module init succeeded!
[ 59.653555] tun: Universal TUN/TAP device driver, 1.6
[ 59.662113] EDMA ver 1 hw init
[ 59.662778] EDMA HW Reset completed succesfully
[ 59.665576] Num rings - TxDesc:1 (23-23) TxCmpl:1 (23-23)
[ 59.669935] RxDesc:1 (15-15) RxFill:1 (7-7)
[ 59.675893] (unnamed net_device) (uninitialized): netif_napi_add() called with weight 100
[ 59.679778] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 59.690173] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 59.695215] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 59.695267] GMAC3(ffffff801dbb6780) Invalid MAC@ - using 52:26:25:57:80:83
[ 59.709887] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 59.712404] GMAC4(ffffff801b9da780) Invalid MAC@ - using ca:76:ab:a0:46:29
[ 59.716755] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 59.725873] GMAC5(ffffff801b9de780) Invalid MAC@ - using 5e:24:4c:57:17:40
[ 59.730960] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 59.740188] **********************************************************
[ 59.745059] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 59.752215] * NSS Data Plane driver
[ 59.766121] **********************************************************
[ 59.770938] l2tp_core: L2TP core driver, V2.0
[ 59.777098] l2tp_netlink: L2TP netlink interface
[ 59.998842] nss_driver - fw of size 859756 bytes copied to load addr: 40000000, nss_id : 0
[ 60.000772] Supported Frequencies -
[ 60.000774] 187.2 MHz
[ 60.006024] 748.8 MHz
[ 60.009802] 1.4976 GHz
[ 60.011972]
[ 60.016722] ffffffc008d21240: set sdma ffffff801b6ef400
[ 60.018494] node size 2 # items 4
[ 60.023349] memory: 40000000 536870912 (avl 448565248) items 4 active_cores 1
[ 60.026850] addr/size storage words 2 2 # words 4 in DTS, ddr size 1000000
[ 60.033945] ffffffc008d21240: NSS core 0 DDR from 40000000 to 41000000
[ 60.040833] ffffffc008d21240: meminfo init succeed
[ 60.052201] ffffffc008d21240: All resources initialized and nss core0 has been brought out of reset
[ 60.052315] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 60.062393] nat46: module (version 1182f30785e4274913f01a8c3d7e1b5437ae3819) loaded.
[ 60.069639] gre: GRE over IPv4 demultiplexor driver
[ 60.076292] node size 2 # items 4
[ 60.080816] memory: 40000000 536870912 (avl 448659456) items 4 active_cores 1
[ 60.084297] addr/size storage words 2 2 # words 4 in DTS, ddr size 1000000
[ 60.091426] ffffffc008d21240: nss core 0 booted successfully
[ 60.098389] ip_gre: GRE over IPv4 tunneling driver
[ 60.107763] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[ 60.118431] PPP generic driver version 2.4.2
[ 60.119191] NET: Registered protocol family 24
[ 60.122779] PPTP driver version 0.8.5
[ 60.155595] i2c-gpio soc:i2c_gpio: using lines 475 (SDA) and 474 (SCL)
[ 60.155716] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 60.161184] GACT probability on
[ 60.169507] Mirror/redirect action on
[ 60.176651] u32 classifier
[ 60.176684] input device check on
[ 60.178264] Actions configured
[ 60.188787] fuse: init (API version 7.31)
[ 60.192001] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 60.195617] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 60.198952] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 60.205400] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x0000000000010010
[ 60.212775] xhci-hcd xhci-hcd.0.auto: irq 96, io mem 0x08a00000
[ 60.223330] hub 1-0:1.0: USB hub found
[ 60.227917] hub 1-0:1.0: 1 port detected
[ 60.231302] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 60.232219] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 60.235694] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 60.242254] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 60.255029] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 60.262684] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 60.269968] hub 2-0:1.0: USB hub found
[ 60.277529] hub 2-0:1.0: 1 port detected
[ 60.281222] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 60.285535] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 60.292458] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 60.301776] usbcore: registered new interface driver cdc_acm
[ 60.306756] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 60.314221] usbcore: registered new interface driver cdc_wdm
[ 60.321210] Loading modules backported from Linux version v3.18-503864-gf8ad1dc
[ 60.326306] Backport generated by backports.git v5.10-rc6-1-1-g884d3b1
[ 60.337305] usbcore: registered new interface driver ipheth
[ 60.343557] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 60.412683] usbcore: registered new interface driver ums-alauda
[ 60.414005] usbcore: registered new interface driver ums-cypress
[ 60.418815] usbcore: registered new interface driver ums-datafab
[ 60.425160] usbcore: registered new interface driver ums-freecom
[ 60.431121] usbcore: registered new interface driver ums-isd200
[ 60.436966] usbcore: registered new interface driver ums-jumpshot
[ 60.442544] usbcore: registered new interface driver ums-karma
[ 60.449076] usbcore: registered new interface driver ums-sddr09
[ 60.454375] usbcore: registered new interface driver ums-sddr55
[ 60.460347] usbcore: registered new interface driver ums-usbat
[ 60.471516] usbcore: registered new interface driver usbserial_generic
[ 60.471574] usbserial: USB Serial support registered for generic
[ 60.479388] wireguard: WireGuard 1.0.20211208 loaded. See www.wireguard.com for information.
[ 60.483556] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
[ 60.507185] xt_time: kernel timezone is -0000
[ 60.508645] usbcore: registered new interface driver cdc_ether
[ 60.512591] usbcore: registered new interface driver cdc_ncm
[ 60.529662] usbcore: registered new interface driver huawei_cdc_ncm
[ 60.549772] usbcore: registered new interface driver qmi_wwan
[ 60.551429] usbcore: registered new interface driver rndis_host
[ 60.616026] usbcore: registered new interface driver option
[ 60.616088] usbserial: USB Serial support registered for GSM modem (1-port)
[ 61.355575] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 61.387251] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 61.387504] scsi host0: usb-storage 2-1:1.0
[ 61.392708] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 63.577429] scsi 0:0:0:0: Direct-Access ORICO U3S-J 1100 PQ: 0 ANSI: 6
[ 63.580006] sd 0:0:0:0: [sda] 120927318 512-byte logical blocks: (61.9 GB/57.7 GiB)
[ 63.584775] sd 0:0:0:0: [sda] Write Protect is off
[ 63.591999] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 63.592148] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 63.599401] sda: sda1
[ 63.607975] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 63.608331] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 64.777846] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 65.685521] ath11k c000000.wifi: Not multipd architecture
[ 65.685786] ath11k c000000.wifi: ipq6018 hw1.0
[ 65.690138] remoteproc remoteproc0: powering up cd00000.remoteproc
[ 65.716849] remoteproc remoteproc0: Booting fw image IPQ6018/q6_fw.mdt, size 7340
[ 66.765535] Subsystem error monitoring/handling services are up
[ 66.771216] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 66.772379] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 66.818224] ath11k c000000.wifi: chip_id 0x0 chip_family 0x4 board_id 0xff soc_id 0xffffffff
[ 66.818265] ath11k c000000.wifi: fw_version 0x27038969 fw_build_timestamp 2024-08-07 06:44 fw_build_id QC_IMAGE_VERSION_STRING=WLAN.HK.2.7.0.1-02409-QCAHKSWPL_SILICONZ-1
I have verified the UUID of the USB drive, and it is correct.**
Device Info:**
  • Model: GL-AX1800 (Flint)
  • Current Firmware: 4.8.3
  • Previous Firmware: 4.6.8
Has anyone else encountered this issue with the latest firmware? Are there any changes in how the mount process or block-mount is handled in 4.8.x?
Any help or suggestions on how to fix this would be greatly appreciated. Thanks in advance!
It appears to be an issue caused by a timing mismatch during the boot sequence.
You can refer to the following OpenWrt issue to see if any of the suggested solutions apply.
Thanks for the suggestions, but they don't seem to resolve the issue for my setup.
Have you tried adding the following lines to /etc/rc.local?
export PREINIT=1
mount_root
This allows extroot to work in our local environment:
If it still doesn’t work, you may need to seek help from the OpenWrt community, as this part of the code is not maintained by us.
I set this up according to this guide 存储扩展 - GL.iNet 文档 , which doesn't specify any requirements for /etc/rc.local, so I left it as is.
The Extroot feature is provided by the underlying OpenWrt system, so that tutorial is for reference only.
We recommend referring to the official OpenWrt documentation instead, as it offers more detailed guidance as well as troubleshooting steps and possible workarounds:
