We will add dependencies on the repo, please await. Thanks.
I can't even download the update package: Downloading https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/kmod-5.4.164/aarch64_cortex-a53_neon-vfpv4/ipq60xx/Packages.gz
*** Failed to download the package list from https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/kmod-5.4.164/aarch64_cortex-a53_neon-vfpv4/ipq60xx/Packages.gz
Downloading https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/packages-5.0/aarch64_cortex-a53_neon-vfpv4/packages/Packages.gz
*** Failed to download the package list from https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/packages-5.0/aarch64_cortex-a53_neon-vfpv4/packages/Packages.gz
Updating database.
Database update completed.
Errors
Failed to send request: Operation not permitted
Collected errors:
opkg_download: Failed to download https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/kmod-5.4.164/aarch64_cortex-a53_neon-vfpv4/ipq60xx/Packages.gz, wget returned 4.
opkg_download: Check your network settings and connectivity.
opkg_download: Failed to download https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/packages-5.0/aarch64_cortex-a53_neon-vfpv4/packages/Packages.gz, wget returned 4.
SQM dependency package has been completed, you can refresh opkg, and install SQM through GL repo.
Please let me know if you have any issue about the SQM.
Thanks.
Please update the repo first, and remove the old sqm
plugins and its dependencies.
If no luck, please reset the firmware, and try to install it again.
A little strange
I tested the opkg update is normally on my AXT1800
(the repo of AX1800 and AXT1800 are the same)
Please check your network, since it is prompted to be an abnormal network.
Please try to change DNS, and available to ping fw.gl-inet.com
available to download it through "wget"?
wget https://fw.gl-inet.com/releases/v23.05-SNAPSHOT/kmod-5.4.164/aarch64_cortex-a53_neon-vfpv4/ipq60xx/Packages.gz
I am able to download and install now. What I did was stop adguard or whatever you did fixed it.
SQM is broken.
Probably that the ADG DNS is not resolved to GL repro.
Please provide detail info about the broken issue, like description and screenshot.
Network acceleration set to On breaks SQM. Disabling fixes it.
