AX1800 Not responding with CRON errors
These are the errors in the log that cause the router to freeze and not respond for like 30 seconds or so:
Fri May 9 15:09:00 2025 cron.err crond[8657]: USER root pid 29332 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Fri May 9 15:09:00 2025 cron.err crond[8657]: USER root pid 29333 cmd . /lib/functions/modem.sh;check_ip
Fri May 9 15:09:00 2025 cron.err crond[8657]: USER root pid 29334 cmd sleep 30;. /lib/functions/modem.sh;check_ip
  1. What firmware version is AX1800?
  2. Is it enabled repeater? If yes, did the router connect the "Multi-APs and same SSID" WiFi through repeater?
  3. These log are normal print. Have you ever connected to USB dongle/ modem, etc., but it will not cause the router to freeze.
    Please check whether the Internet and router are working properly on your PC: ping the [router LAN IP] and ping www.google.com.
  4. Please share the issue syslog with us and let us know your network topology diagram.
  1. Firmware: 4.7.0
  2. No Repeater. wired Ethernet to AX1800 and C7800 modem.
  3. Netgear C7800 Modem > AX1800>PC
  4. Can't post the log too large but here is what i can post: Wed May 14 11:55:30 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:30.194046 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:41178->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:30 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:30.194172 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;nest-camera-media-upload.googleapis.com. IN A in 20.002421958s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:41178->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:30 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:30.806698 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:59215->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:30 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:30.806875 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;swallow-apple-com.v.aaplimg.com. IN A in 20.001460818s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:59215->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:30 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:30.806690 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:36292->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:30 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:30.807307 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;swallow-apple-com.v.aaplimg.com. IN HTTPS in 20.00278258s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:36292->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:34 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:34.830949 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:38424->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:34 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:34.831200 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;fw.gl-inet.com. IN A in 20.002042495s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:38424->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:39 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:39.836660 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:60513->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:39 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:39.836824 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;fw.gl-inet.com. IN A in 20.002543122s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:60513->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:44 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:44.805360 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:39590->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:44 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:44.805546 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;deviceapi.messaging.arlo.com. IN A in 20.001995363s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:39590->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:44 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:44.805419 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:58091->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:44 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:44.806031 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;mcs.arlo.com. IN A in 20.002248783s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:58091->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:44 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:44.824139 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:48137->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:44 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:44.824300 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;fw.gl-inet.com. IN A in 20.002782663s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:48137->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:44 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:44.840115 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:60678->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:44 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:44.840270 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;fw.gl-inet.com. IN A in 20.001075146s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:60678->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:47 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:47.933486 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:43708->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:47 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:47.933671 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;www.gstatic.com. IN A in 20.002463591s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:43708->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:47 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:47.933486 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:39881->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:47 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:47.933862 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;www.gstatic.com. IN HTTPS in 20.002677759s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:39881->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:49 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:49.829484 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:36112->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:49 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:49.829650 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;fw.gl-inet.com. IN A in 20.00281691s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:36112->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:49 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:49.846842 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:33903->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:49 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:49.847008 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;fw.gl-inet.com. IN A in 20.002701867s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:33903->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:50 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:50.432243 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:42059->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:50 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:50.432512 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;mcs.arlo.com. IN A in 20.001681769s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:42059->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:50 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:50.432235 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:58948->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:50 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:50.432680 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;deviceapi.messaging.arlo.com. IN A in 20.002496027s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:58948->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:50 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:50.432254 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:55278->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:50 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:50.433124 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;mcs.arlo.com. IN A in 20.003028948s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:55278->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:54 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:54.833343 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:51527->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:54 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:54.833494 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;fw.gl-inet.com. IN A in 20.002172817s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:51527->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:55 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:55.522663 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:39789->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:55 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:55.522837 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;mcs.arlo.com. IN A in 20.003174529s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:39789->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:55 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:55.522663 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:50418->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:55 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:55.523224 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;mcs.arlo.com. IN A in 20.002104561s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:50418->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:55 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:55.523562 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:36715->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:55 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:55.523667 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;deviceapi.messaging.arlo.com. IN A in 20.0019461s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:36715->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:55 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:55.526107 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:54310->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:55 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:55.526400 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;35.94.245.35.bc.googleusercontent.com. IN AAAA in 20.001339678s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:54310->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:56 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:56.039025 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:43698->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:56 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:56.039194 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;a1931.dscgi3.akamai.net. IN A in 20.002698562s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:43698->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.660977 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:39628->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.661162 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;weatherkit.apple.com. IN A in 20.001870354s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:39628->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.660977 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:39150->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.661715 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;weatherkit.apple.com. IN HTTPS in 20.002408235s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:39150->1.1.1.1:53: i/o timeout
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.720378 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:49814->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.720707 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;deviceapi.messaging.arlo.com. IN A in 20.00265782s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:49814->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.720370 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:60146->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.720556 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:45662->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.721291 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;mcs.arlo.com. IN AAAA in 20.001568601s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:45662->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.721171 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;mcs.arlo.com. IN A in 20.002221149s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:60146->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.722389 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:43986->1.0.0.1:53: i/o timeout"
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.722520 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;deviceapi.messaging.arlo.com. IN AAAA in 20.001152388s: exchanging with 1.0.0.1:53 over udp: read udp 192.168.0.14:43986->1.0.0.1:53: i/o timeout
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.839697 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:57148->1.1.1.1:53: i/o timeout"
    Wed May 14 11:55:59 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:55:59.839860 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;fw.gl-inet.com. IN A in 20.002912154s: exchanging with 1.1.1.1:53 over udp: read udp 192.168.0.14:57148->1.1.1.1:53: i/o timeout
    Wed May 14 11:56:00 2025 daemon.notice netifd: Network device 'eth2' link is down
    Wed May 14 11:56:00 2025 kern.info kernel: [32142.008770] nss-dp 3a001400.dp3 eth2: PHY Link is down
    Wed May 14 11:56:00 2025 kern.info kernel: [32142.009205] br-lan: port 2(eth2) entered disabled state
    Wed May 14 11:56:00 2025 cron.err crond[5102]: USER root pid 637 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
    Wed May 14 11:56:00 2025 cron.err crond[5102]: USER root pid 638 cmd . /lib/functions/modem.sh;check_ip
    Wed May 14 11:56:00 2025 cron.err crond[5102]: USER root pid 639 cmd sleep 30;. /lib/functions/modem.sh;check_ip
    Wed May 14 11:56:00 2025 cron.err crond[5102]: USER root pid 640 cmd . /lib/functions/modem.sh;modem_net_monitor
    Wed May 14 11:56:02 2025 kern.info kernel: [32144.088794] nss-dp 3a001400.dp3 eth2: PHY Link up speed: 1000
    Wed May 14 11:56:02 2025 kern.info kernel: [32144.088925] br-lan: port 2(eth2) entered blocking state
    Wed May 14 11:56:02 2025 kern.info kernel: [32144.093538] br-lan: port 2(eth2) entered forwarding state
    Wed May 14 11:56:02 2025 daemon.notice netifd: Network device 'eth2' link is up
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[4023]: exiting on receipt of SIGTERM
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: started, version 2.89 cachesize 1
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: compile time options: IPv6 GNU-getopt no-RTC no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: UBus support enabled: connected to system bus
    Wed May 14 11:56:03 2025 daemon.info dnsmasq-dhcp[879]: DHCP, IP range 10.8.4.100 -- 10.8.4.249, lease time 12h
    Wed May 14 11:56:03 2025 daemon.info dnsmasq-dhcp[879]: IPv6 router advertisement enabled
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: using nameserver 127.0.0.1#5453
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: using only locally-known addresses for test
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: using only locally-known addresses for onion
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: using only locally-known addresses for localhost
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: using only locally-known addresses for invalid
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: using only locally-known addresses for bind
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: using only locally-known addresses for lan
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: read /etc/hosts - 12 names
    Wed May 14 11:56:03 2025 daemon.info dnsmasq[879]: read /tmp/hosts/dhcp.cfg01411c - 4 names
    Wed May 14 11:56:03 2025 daemon.info dnsmasq-dhcp[879]: read /etc/ethers - 0 addresses
    Wed May 14 11:56:03 2025 daemon.info dnsmasq-dhcp[879]: DHCPREQUEST(br-lan) 10.8.4.240 a8:51:ab:cf:26:e5
    Wed May 14 11:56:03 2025 daemon.info dnsmasq-dhcp[879]: DHCPACK(br-lan) 10.8.4.240 a8:51:ab:cf:26:e5 EntertamentRoom
    Wed May 14 11:56:05 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:56:05.969496 [info] Received signal "terminated"
    Wed May 14 11:56:05 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:56:05.969712 [info] stopping AdGuard Home
    Wed May 14 11:56:05 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:56:05.969781 [info] stopping http server...
    Wed May 14 11:56:05 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:56:05.970103 [info] stopped http server
    Wed May 14 11:56:05 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:56:05.970278 [info] dnsproxy: stopping server
    Wed May 14 11:56:05 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:56:05.970566 [info] dnsproxy: stopped dns proxy server
    Wed May 14 11:56:05 2025 user.notice AdGuardHome[7689]: 2025/05/14 11:56:05.988382 [info] stopped
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] dnscrypt-proxy 2.1.5
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] dnscrypt-proxy 2.1.5
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] Network connectivity detected
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] Now listening to 127.0.0.1:5454 [UDP]
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] Now listening to 127.0.0.1:5454 [TCP]
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] Service is not usable yet
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] Resolving server host [raw.githubusercontent.com] using bootstrap resolvers over udp
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] Network connectivity detected
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] Now listening to 127.0.0.1:5453 [UDP]
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] Now listening to 127.0.0.1:5453 [TCP]
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] Service is not usable yet
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] Resolving server host [raw.githubusercontent.com] using bootstrap resolvers over udp
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] Source [relays] loaded
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] Source [public-resolvers] loaded
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] Source [relays] loaded
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:08] [NOTICE] Resolving server host [download.dnscrypt.info] using bootstrap resolvers over udp
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] Source [odoh-servers] loaded
    Wed May 14 11:56:08 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:08] [NOTICE] Resolving server host [download.dnscrypt.info] using bootstrap resolvers over udp
    Wed May 14 11:56:09 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:09] [NOTICE] Source [odoh-servers] loaded
    Wed May 14 11:56:09 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:09] [NOTICE] Firefox workaround initialized
    Wed May 14 11:56:09 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:09] [NOTICE] Loading the set of blocking rules from [blocked-names.txt]
    Wed May 14 11:56:09 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:09] [NOTICE] [cloudflare] OK (DoH) - rtt: 58ms
    Wed May 14 11:56:09 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:09] [NOTICE] Server with the lowest initial latency: cloudflare (rtt: 58ms)
    Wed May 14 11:56:09 2025 daemon.err dnscrypt-proxy[1397]: [2025-05-14 11:56:09] [NOTICE] dnscrypt-proxy is ready - live servers: 1
    Wed May 14 11:56:11 2025 daemon.notice netifd: Network device 'eth2' link is down
    Wed May 14 11:56:11 2025 kern.info kernel: [32152.488798] nss-dp 3a001400.dp3 eth2: PHY Link is down
    Wed May 14 11:56:11 2025 kern.info kernel: [32152.489318] br-lan: port 2(eth2) entered disabled state
    Wed May 14 11:56:15 2025 kern.info kernel: [32156.648660] nss-dp 3a001400.dp3 eth2: PHY Link up speed: 1000
    Wed May 14 11:56:15 2025 kern.info kernel: [32156.648848] br-lan: port 2(eth2) entered blocking state
    Wed May 14 11:56:15 2025 kern.info kernel: [32156.653397] br-lan: port 2(eth2) entered forwarding state
    Wed May 14 11:56:15 2025 daemon.notice netifd: Network device 'eth2' link is up
    Wed May 14 11:56:16 2025 daemon.notice netifd: Network device 'eth2' link is down
    Wed May 14 11:56:16 2025 kern.info kernel: [32157.688645] nss-dp 3a001400.dp3 eth2: PHY Link is down
    Wed May 14 11:56:16 2025 kern.info kernel: [32157.689203] br-lan: port 2(eth2) entered disabled state
    Wed May 14 11:56:17 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:17] [NOTICE] Source [public-resolvers] loaded
    Wed May 14 11:56:17 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:17] [NOTICE] Firefox workaround initialized
    Wed May 14 11:56:17 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:17] [NOTICE] Loading the set of blocking rules from [blocked-names.txt]
    Wed May 14 11:56:17 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:17] [NOTICE] [cloudflare] OK (DoH) - rtt: 19ms
    Wed May 14 11:56:17 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:17] [NOTICE] Server with the lowest initial latency: cloudflare (rtt: 19ms)
    Wed May 14 11:56:17 2025 daemon.err dnscrypt-proxy[1383]: [2025-05-14 11:56:17] [NOTICE] dnscrypt-proxy is ready - live servers: 1
    Wed May 14 11:56:18 2025 kern.info kernel: [32159.768645] nss-dp 3a001400.dp3 eth2: PHY Link up speed: 1000
    Wed May 14 11:56:18 2025 kern.info kernel: [32159.768811] br-lan: port 2(eth2) entered blocking state
    Wed May 14 11:56:18 2025 kern.info kernel: [32159.773387] br-lan: port 2(eth2) entered forwarding state
    Wed May 14 11:56:18 2025 daemon.notice netifd: Network device 'eth2' link is up
    Wed May 14 11:56:20 2025 daemon.notice netifd: Network device 'eth2' link is down
    Wed May 14 11:56:20 2025 kern.info kernel: [32161.848594] nss-dp 3a001400.dp3 eth2: PHY Link is down
    Wed May 14 11:56:20 2025 kern.info kernel: [32161.849093] br-lan: port 2(eth2) entered disabled state
    Wed May 14 11:56:22 2025 daemon.notice netifd: Network device 'eth2' link is up
    Wed May 14 11:56:22 2025 kern.info kernel: [32163.928587] nss-dp 3a001400.dp3 eth2: PHY Link up speed: 100
    Wed May 14 11:56:22 2025 kern.info kernel: [32163.928712] br-lan: port 2(eth2) entered blocking state
    Wed May 14 11:56:22 2025 kern.info kernel: [32163.933326] br-lan: port 2(eth2) entered forwarding state
    Wed May 14 11:57:00 2025 cron.err crond[5102]: USER root pid 2104 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
    Wed May 14 11:57:00 2025 cron.err crond[5102]: USER root pid 2105 cmd . /lib/functions/modem.sh;check_ip
    Wed May 14 11:57:00 2025 cron.err crond[5102]: USER root pid 2106 cmd sleep 30;. /lib/functions/modem.sh;check_ip
    Wed May 14 11:58:00 2025 cron.err crond[5102]: USER root pid 2718 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
    Wed May 14 11:58:00 2025 cron.err crond[5102]: USER root pid 2719 cmd . /lib/functions/modem.sh;check_ip
    Wed May 14 11:58:00 2025 cron.err crond[5102]: USER root pid 2720 cmd sleep 30;. /lib/functions/modem.sh;check_ip
    Wed May 14 11:58:00 2025 cron.err crond[5102]: USER root pid 2721 cmd . /lib/functions/modem.sh;modem_net_monitor
Also, I have been having problems with connection since update 4.5. I even had an issue that the SQM didn't reload after a reboot. I have rolled back to 4.4.6 and things work great. The speed and the SQM works when you reboot daily.
  1. Checked the syslog you attached, it seems that the network port (LAN2) has down. In v4.7.0 you try SSH to the router, and execute the commands, to observe if this issue reproduce again:
ethtool --set-eee eth2 eee off
ethtool --set-eee eth1 eee off
ethtool --set-eee eth0 eee off
  1. Regarding the plug-in SQM, please try to completely remove this plug-in and reinstall it, and disable the hardware acceleration, to check whether SQM is loaded after the router restarts.
It's probably one of the devices going in and out of sleep mode. Apple TV is the culprit.
BusyBox v1.33.2 (2023-09-08 06:17:16 UTC) built-in shell (ash)
| - || _ | -
____|| |
|__| W I R E L E S S F R E E D O M
ApNos-d303bd39-devel
OpenWrt 21.02-SNAPSHOT, r16399+159-c67509efd7
root@HUH:~#
root@HUH:~# root@HUH:~# ethtool --set-eee eth2 eee off
-ash: root@HUH:~#: not found
root@HUH:~# eee unmodified, ignoring
-ash: eee: not found
root@HUH:~#
root@HUH:~#
root@HUH:~# root@HUH:~# root@HUH:~# ethtool --set-eee eth2 eee off
root@HUH:~# -ash: root@HUH:~#: not found
-ash: -ash:: not found
root@HUH:~# root@HUH:~# eee unmodified, ignoring
-ash: -ash: eeeroot@HUH:~#: not found: not found
root@HUH:~# -ash: eee: not found
root@HUH:~#
ethtool --set-eee eth3 eee off
ethtool --set-eee eth4 eee off
These commands are used in the AX1800/AXT1800 v4.7.0 firmware.
Others v4.5.x / v4.6.x cannot be used.
Please try to see if there will be any improvement.
