I've got a remote AX1800 that i just discovered is only running 4.2.0 (Yes, I know I can force a local update) Upgrade window shows "Firmware is up to date. "
My real question is why is not not finding the latest version? Is there some way to trigger it to check for new firmware, or a log file I can look at to see whats failing? A quick check of logs via gui is not showing much.
In any case I will wait until I am on location before messing with it too much.
Thanks!
