I am running stable 3.213 on AX1800.
I have a problem with VPN Policies. It is not a big problem but annoying. If i start a wireguard client and i also have VPN Policies that some macs dont use the vpn , the policies are not working. Every mac gets VPN.
The workaround is to setup the policies, start the VPN and then reboot the router. Then everything is working perfectly
Can you fix it in future firmware?
