Hi there, I have been using Flint for about six weeks now without major hiccups. However, I just moved for work and now have to connect Flint to a 5GHz DFS network (I have noticed it using channels 60 and several ones within the 112-140 range so far).
On the admin scanning page this option is greyed out and I also cannot edit this via luci. I checked the forum extensively and found a few suggested workarounds, but they all involve other routers and have not worked for (my) Flint, currently running 3.207. Most suggestions involved editing the /config/wireless settings but no playing around with channels, countries (Germany here) or providing the relevant mac address has had any lasting positive effect. I managed to connect to the WiFi twice when it was on Channel 60 by manually setting it in the config, but then lost the connection in the minutes/hours afterwards when the router switched to a three-digit channel again.
Can anyone please point me to a Flint-specific solution on how it can automatically connect to DFS networks that change their channels in the above mentioned ranges frequently? Thank you!
