安装openclash插件已经能正常显示了,但是启动后提示缺少libcap和libcap-bin,换源安装尝试了好几个版本还是提示缺少环境,不知道怎么解决现在 ![]()
openclash是armv7的
package源选的是snapshot的a53
openclash是armv7的
You maybe use shellclash to install that could find in github.com,a friend told me in QQ chat.
You could try it.
I had the same problem as todoke. It doesn’t seem to be possible to install openclash or clash using the normal methods because of the old version of openwrt.
However, I can confirm that it does work with shellclash! It’s kind of difficult for someone (like me) who doesn’t read Chinese, but I was still able to figure it out and get it running.
If you’re already familiar with clash, ssh, and Chinese then it should be easy, if not then good luck!
thanks a lot, I will try it
Thank you very much for your reply , I will try it out ![]()
I’m poor in English but Chinese is my native language hhh.
It’s really helpful, thanks again ![]()
