I’m trying to force https for local access.
The toggle switch turns on but the apply button greys out and won’t apply the setting?
anyone have any clues why this would be and is there a fix?
FW: 4.5
Not sure what you are trying to do.
What function do you want to use the Toggle Switch button to do?
Sorry I didn’t explain very well, not the physical toggle switch, the switch to force https in system → security - local access control. When toggled to on the apply button greys out. Or does that mean it’s applied already?
Not sure. But maybe just try and see.
