hello ,a bit nub here
i installed tor package for a test ,
and when installed ,router use it by defaut …
when i just want made a relay and no use it for me …
so i installed package ,
but when im trying to uninstall it i have this error
hello ,
thank’s for anwsers but im under iphone …
i need a ssh client ?
im working on the interface ,so i dont see any ssh / console
i will check it …
same i go uninstall gl-sdk4-tor : uninstallation failled
: the software uninstall unsupported
yep sorry ,
i do it with in terminal ssh root/password
opkg remove gl-sdk4-tor --forceremova…
all look uninstall , ( i got a succesfull )
i reboot the device ,
but my ip was a tor exit again
i go under “admin panel” plugins go to tor
it show it was installed , uninstall ; same error at first post …
sorry im a 0 under linux …
hardware is new ( nothing important installed on it )
i see a reset firmware, it no clean the device to factory ?
or any easy way to do this ( get it like a new device ? )
oups reset isnt a hole , i do it , sorry it’s “solved” xD
