Just bought a new GL-iNet AX3000, and the router 's inbuilt VPN can't be occnected to. Pls nay suggestion , how I can fix this ?
please provide more information, see How to get support quickly
and How to troubleshoot WireGuard
I Just setup my GL-iNet AX3000. I connected to my home network via Wifi,using it as a repeater. Now tried connecting the VPN. I initially tried the inbuilt VPN using Nord VPN. that didnt work, I later now DownVPN configurator from Private internet access to configure manually it still dint connect to the VPN. So both the inbuilt VPN app and external aren't connecting.
In which country is your router located?
United Kingdom
Dif you already updated to the latest firmware? You will find it here: https://dl.gl-inet.com
Please share your logs which might indicate what is going wrong with your connection.
