I am using an AXT 1800. I connect to WeWork WiFi and everything works. After a few minutes, the internet drops and the WiFi has disconnected. This has happened a few times now.
Then my connection to the AXT drops completely (it is connected via ethernet to my laptop) and I cannot access 192.168.8.1.
I used it everyday this past week. I connect to it, it stays online for 5-6 hours, then goes offline. Then I reconnect and it’s back to working (perhaps WeWork kicks a device off after being connected for a long time)?
But today, it’s different. Frequent disconnects. Maybe it’s the weekend so WeWork is performing maintenance?
It’s working as we speak (1 device connected via ethernet and 1 via repeater mode).
Yeah, the period on the Multi-WAN; 1.5x their current values or so helped.
I don’t use WeWork but I seem to recall fr an older thread they recently started using DFS on their Wi-Fi APs. @admon , do you recall anything about that? You know how quickly threads get buried 'round here.
Hah! Too funny! Sorry I don’t know for sure but I’d still give increasing the periods & change out the pinged IPs to something like Cloudflare (1.1.1.1, 1.1.1.2). Cloudflare has very fast infrastructure if you don’t care about hitting their sever logs w/ your IP.
Even if they use DFS it would not explain why the disconnection happens so often.
DFS is every 3 or 6 hours or something like that. Would be strange for a Co-Working space if they interrupt every video call like twice an hour just to do DFS stuff.
For reference, my setup includes a Wireguard VPN tunnel using (2) AXT 1800s. One is in the US connected to residential router. The other is with me (travel router).
I’m having the same issues but I’m using this router at home or when I’m on travel. The only difference is the when I reboot or power cycle the router it will connect to the network but there’s no connection! I reset the travel router and the same issue.
