I guess you set up the OpenVPN Server on OPNsense and then exported the client configuration to the AXT1800?
Is openvpn.p12 the file you exported from OPNsense?
I think you need to convert the .p12 file to CA certificate, client certificate and client private key.
Yes the P12 file is exported from OPNSense along with open config and tls key file
Do you have a sample what they looks like ?
What kind of format is needed for CA cert and client cert ?
It would be really helpful if you make an insturction here.
Also in ovpn file I have changed from pkcs12 OpenVpn.p12 to pem open.crt
and this the error log:
Sat Jan 14 12:52:23 2023 daemon.notice netifd: Interface ‘ovpnclient’ is setting up now
Sat Jan 14 12:52:23 2023 daemon.err ovpnclient[5782]: Options error: Unrecognized option or missing or extra parameter(s) in /tmp/ovpnclient/ovpnclient:12: pem (2.5.3)
Sat Jan 14 12:52:23 2023 daemon.warn ovpnclient[5782]: Use --help for more information.
