AXT 1800 (slate) - additional way to internet using a SIM card?
Dear all,
I'm using an AXT 1800 (slate), which acts as router with VPN to the internet.
It connects through a RJ-45 cable to my Fritz!Box (DSL).
Sadly my internet connection (DSL) has too often issues and I may have no internet for minutes or hours.
I'm considering buying a mobile data subscription and put a SIM card into the router.
First question : It is supported to have 2 "sources" for internet in a single AXT 1800 ? If so - can I use both together or do I have to switch?
Second question : Can someone pls. provide me a link to a good (English or German) manual for using internet through mobile data with the AXT 1800?
THX in advance and best regards!
First thing first, the AXT1800 ist not a mobile (LTE/5g) travel router, refer to this post :point_down:
Hello gfondeur,
THX a lot for clarifying that.
I don't know why, but I always thought, that the slot is for a SIM card :wink:
And also thanks for the list of those devices that can use such a SIM card :slight_smile:
Best regards!
  1. Support. When your Ethernet network is disconnected, it will automatically switch to another network.
  2. You can refer to the link below.
    Cellular - GL.iNet Router Docs 4
