AXT1800 crash, if i set a dns entry in to whitelist
i use a GL Intet AXT1800. At the moment i am in Holiday and use the Router daily. Some Users want to use some websites. the websites blocked with the adblock lists. So i whitelisted some entries in the protocol. after i click on “unlock” the router crashes completely. I cant say why. the logs are not visible. i only can see the logs after boot.
Router Firmware: v4.5.16
Adguard Home Version
Any ideas, how i can solve this problem? With this issues i cant use adguard home, cause if iam not in out holiday home and other want to use internet, the router crashes often, its pain.
thanks
Please upgrade AdGuard Home
Hey,
i updated with the script and make it permanent
Log:
root@GL-AXT1800:~# wget -O update-adguardhome.sh https://raw.githubusercontent.com/Admonstrator/glinet-adguard-updater/main/update-adguardhome.sh && sh update-adguardhome.sh
--2024-05-06 22:32:05--  https://raw.githubusercontent.com/Admonstrator/glinet-adguard-updater/main/update-adguardhome.sh
Resolving raw.githubusercontent.com... 185.199.108.133, 185.199.111.133, 185.199.110.133, ...
Connecting to raw.githubusercontent.com|185.199.108.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 13505 (13K) [text/plain]
Saving to: 'update-adguardhome.sh'
update-adguardhome.sh                            100%[========================================================================================================>]  13.19K  --.-KB/s    in 0.001s
2024-05-06 22:32:05 (18.1 MB/s) - 'update-adguardhome.sh' saved [13505/13505]
[2024-05-06 22:32:05] [→] Checking if prerequisites are met ...
[2024-05-06 22:32:05] [✓] Firmware version: 4
[2024-05-06 22:32:05] [✓] Architecture: armv7
[2024-05-06 22:32:05] [✓] Available space: 35 MB
[2024-05-06 22:32:05] [✓] curl is installed.
[2024-05-06 22:32:05] [✓] wget is installed.
[2024-05-06 22:32:05] [✓] Prerequisites are met.
[2024-05-06 22:32:05] [✓] You are using the latest version of this script!
│ GL.iNet router script by Admon 🦭 for the GL.iNet community            |
| Version: 2024.05.06.01                                                 |
│ WARNING: THIS SCRIPT MIGHT POTENTIALLY HARM YOUR ROUTER!               │
│ It's only recommended to use this script if you know what you're doing.│
│ This script will update AdGuard Home on your router.                   │
| Are you sure you want to continue? (y/N)         |
y
[2024-05-06 22:32:14] [→] Creating backup of AdGuard Home config ...
[2024-05-06 22:32:37] [→] Backup created: /root/AdGuardHome_backup.tar.gz
[2024-05-06 22:32:37] [→] Downloading latest Adguard Home version ...
[2024-05-06 22:32:39] [→] Extracting Adguard Home ...
[2024-05-06 22:32:41] [✓] AdGuardHome binary found, download was successful!
[2024-05-06 22:32:41] [→] Stopping Adguard Home ...
[2024-05-06 22:32:46] [→] Moving AdGuardHome to /usr/bin ...
[2024-05-06 22:32:51] [→] Removing temporary files ...
[2024-05-06 22:32:51] [→] Restarting AdGuard Home ...
| The update was successful. Do you want to make the installation permanent?                               |
| This will make your AdGuard Home config persistant - even after a firmware up-/ or downgrade.            |
| It could lead to issues, even if not likely. Just keep that in mind.                                     |
| In worst case, you might need to remove the config from /etc/sysupgrade.conf and /etc/rc.local.          |
| Do you want to make the installation permanent? (y/N)                                                    |
y
[2024-05-06 22:33:01] [→] Making installation permanent ...
[2024-05-06 22:33:01] [→] Creating persistance script in /usr/bin/enable-adguardhome-update-check ...
[2024-05-06 22:33:01] [→] Creating entry in rc.local ...
[2024-05-06 22:33:01] [→] Modifying /etc/sysupgrade.conf ...
[2024-05-06 22:33:01] [✓] Script finished.
root@GL-AXT1800:~#
After i enabled adguard again and test simple unlock a blocked Entry.
Crash
After reboot, Crash again with test. No adguard or Router GUI available. I need cut the power.
Adguard after Update unusable.
What kind of whitelist entry are you trying to add?
Maybe you can provide a screenshot?
I tried it with my device right now and everything is working as expected.
I saw a blocked gmx.net entry in the protocol. that one i wanted to whitelisting. no i cant, cause at the moment i dont use it, cause i need it for productivity. Sunday we are back at home. On Sunday i can reenable adguard.
So, i tried it again and it crashing after whitelisting
After click on "unlock" the site is not available, the router webgui to. i need to put off the powerplug and put in again for reboot.
