Here is a rough diagram of current setup:
AXT1800 in Extender mode with WiFi connection to “LAN1” via an access point connected via Ethernet to the switch.
- No access to AXT1800 management interface so everything is stuck “as is.” I am told this is normal?
- No access to devices connected to LAN ports of AXT1800 from devices connected via Ethernet to switch (red route)
- No access to devices connected to LAN ports of AXT1800 if connected to “LAN1” WiFi (red route)
- Access to devices connected to LAN ports of AXT1800 only from wireless devices connected to AXT1800 WiFi “LAN2” (green route)
Is this the way Extender mode is supposed to work? Access to devices connected to AXT1800 is only through a WiFi connection to the AXT1800 and from nothing in “LAN1”?
The devices connected to the AXT1800 are Ethernet only and I am using the AXT1800 to WiFi extend/bridge them to the main LAN. There is no way to connect the AXT1800 via Ethernet cable to the switch.
