AXT1800 Keeps Factory Resetting When Rebooting
I am having an issue where my router keeps resetting its settings to factory default. Very annoying!
I can login, change SSDIs, set repeater information, etc., just fine. Then after rebooting or unplugging the unit from the wall and plugging it back on, it appears to be a fresh unit.
I am upgraded to 4.0.3.
Can you post the system log?
When this happens, can you do a firmware reset and try again?
This happens when the flash is full. Not sure if this is your case.
Doing a reset via the software after the issue seems to have resolved my issue! It seems to be maintaining the settings that I change after unplugging and/or rebooting.
Thank you! I will let you know if I come across this problem again.
