hello,
just purchased a gl-axt1800, should arrive tomorrow.
— so i wanted to check out openwrt support at https://openwrt.org/toh/start?dataflt%5BBrand*%7E%5D=GL.iNet
i did not find the router in the router database, my mistake or what?
— at https://dl.gl-inet.com/?model=axt1800&type=clean,
there are no firmware images?
thanks,
david
There are 2 stable firmware versions for download, but no clean (only LuCI, no GL.iNet web Admin Panel) versions.
thanks @wcs2228.
the issue is that i want to understand the new router, in detail.
i am expecting the minimum, basic info, same as my cute USB150
https://openwrt.org/toh/gl.inet/gl-usb150
i would like to hear from official gl-inet employee about this.
thanks,
david
alzhao
4
OpenWrt is adding more and more wifi6 routers and I think eventually they will add.
But for hardware like USB150 form factor, it is just hard to do it agian.
i understand about the usb150, it is old and EOL.
but to have the basic info for ax1800/atx1800 would be nice.
the same basic info as i want from openwrt.
thanks
alzhao
6
Understood. Let’s see if this can be added.
one of the reasons i ask,
to find a clear, definitive answer to this open topic.
I guess that It should be OK.
if posssible, please add the specifications to the gl-inet website
https://docs.gl-inet.com/en/3/specification/gl-axt1800/
