Hi All
I’m using an AXT1800 as a repeater - to give internet access to my doorbell (the doorbell requires internet to communicate with me via wifi)… in any case, all is well for several weeks until the unit just completely resets… and I have to reconfigure it from scratch…
I’m wondering what I’m doing wrong? Is this being hacked by someone? I’m in another time zone, and need someone onsite to help me reconfigure… but will there be anything in the logs that will help me figure this out? or is it a total loss?
Any advice or insight would be greatly appreciated.
Do you mean the router just reboot or it reset (configuration completely gone)?
If it is the former, pls check power adapter. Are you using the stock one or other PD adapters.
If it is the later, may be it is due to some system problems. In this case, you should just try reset the firmware manually once, configure it again, reboot and check if everything is OK.
