AXT1800 (Slate AX) 4.7.0 missing shadowsocks-libdev packages
Is there a plan to add the shadowsocks-libdev packages to the SlateAX 4.7.0 FW? I've had a few clients using SS on 4.6.11 and the packages were lost on upgrade to 4.7.0, with no way to re-add them via the plug-in manager. I've had to downgrade each router and re-setup from scratch.
The SS packages are essential to some GL customers working in countries with restrictive country-level firewalls where traditional VPN protocols (WG, OVPN, etc) cannot connect.
Thank you!
