GL.iNET newbie here. I have completed intallation of my new ATX1800 over the last couple of weeks. Great success with everything so far, it’s an excellent device for my home network.
Today I attached a 32 GB USB drive to the router and set up SAMBA sharing to one User with writable access. My workstation is Windows 11, I have mapped the storage as a Network Location. All looking good at first. I have been able to create folders, create new documents, modify and delete them. I can drag and drop folders and some document types from my workstation onto the storage device with no problems.
Unfortunately I am not able to drag and drop .PDF, image or video files to the storage device. Strangely, I can drag and drop a MS Word document but not an MS Excel workbook. Simple text documents are just fine.
For those file types that fail I am receiving a message “Could not find this item…This is no longer located in ”. Holding the Ctrl key whilst dragging and dropping, to Copy the item to the mapped drive, gives the same failure.
I have enabled SMB 1.0 on my Windows workstation but this does not make any difference, so I have disabled it again.
Through the OpenWRT LuCI web GUI I can see permissions for the SAMBA share are Create mask: 0666 and Directory mask: 0777.
Any ideas as to what I am missing?
Thanks,
Andrew
