AXT1800 SQM Not Working For Download
I installed SQM on my AXT1800 device, although I made all the settings based on GL.inet documents, I cannot reduce the download latency in any way. Upload Latency is +0 ms, but no matter what I do, the download latency does not decrease. I tried to get support from artificial intelligence such as Chatgpt, Deepseek, but in vain. Can you help me with this issue?
I have 100mbps download, 20mbps upload speed and my settings are as follows.
I remember reading somewhere that there was a known issue in 4.6.8 for AX-1800 where you would want to restart via command line using this command: /etc/init.d/sqm restart since SQM wasn't applying correctly after reboot.
If you are running 4.7.0 I can't confirm if it is fixed or not since I did a reflash of 4.6.8 because of the missing components and SQM not being available so I run that command every single reboot I do to properly apply SQM.
Hope it helps.
I have also completely restarted the device, I have also tried factory resetting and reconfiguring it from scratch... It does not work at all. Upload latency but not download latency. Actually, I think upload latency wouldn't work if it didn't work. Why is this happening?
It's hard to know what is happening if you are not providing versions or whether you attempted what I mentioned in my post or not.
Hardware acceleration may be incompatible with plug-in SQM.
If need to use SQM, please disable the hardware acceleration on GL GUI -> Network -> Network Acceleration -> Disable.
Even though everything was set up as specified, I'm facing a terrible result. I'm about to lose my mind. When I unplug the AXT1800 and plug in the service provider's own router, the download latency is between 22-30. It's ridiculous.
On previous firmware versions, such as v4.6.8 + SQM QoS, is there any issue like this?
Will issue there be improvements if the plug-in SQM QoS are not enabled on v4.7.0?
