I received my AXT1800 device the other day and I’m having trouble connecting to IPVanish. The router’s firmware is 4.0.0, release3, 2022-06-03 18:19:56(UTC+08:00).
I downloaded IPV’s OpenVPN config files and removed all of them except for ‘ca.ipvanish.com.crt’ and the ovpn files for the nearest IPVanish POP. Those were uploaded to the router successfully and without any errors. My username and password are entered in. The following is what I’m seeing in the log file. I also tried connecting without removing any of the ovpn files from the zipped config but I’m getting the same errors. TIA for your assistance!
OpenVPN Log
Fri Jul 8 17:55:17 2022 daemon.notice ovpnclient[724]: library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10
Fri Jul 8 17:55:17 2022 daemon.warn ovpnclient[724]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Jul 8 17:55:17 2022 daemon.err ovpnclient[724]: OpenSSL: error:02001002:system library:fopen:No such file or directory
Fri Jul 8 17:55:17 2022 daemon.err ovpnclient[724]: OpenSSL: error:2006D080:BIO routines:BIO_new_file:no such file
Fri Jul 8 17:55:17 2022 daemon.err ovpnclient[724]: Cannot load CA certificate file ca.ipvanish.com.crt (no entries were read)
Fri Jul 8 17:55:17 2022 daemon.notice ovpnclient[724]: Exiting due to fatal error
Fri Jul 8 17:55:22 2022 daemon.notice netifd: Interface 'ovpnclient' is now down
Fri Jul 8 17:55:22 2022 daemon.notice netifd: Interface 'ovpnclient' is setting up now
Fri Jul 8 17:55:23 2022 daemon.warn ovpnclient[1135]: WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
Fri Jul 8 17:55:23 2022 daemon.warn ovpnclient[1135]: DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
Fri Jul 8 17:55:23 2022 daemon.warn ovpnclient[1135]: WARNING: --keysize is DEPRECATED and will be removed in OpenVPN 2.6
Fri Jul 8 17:55:23 2022 daemon.notice ovpnclient[1135]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Fri Jul 8 17:55:23 2022 daemon.notice ovpnclient[1135]: library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10
Fri Jul 8 17:55:23 2022 daemon.warn ovpnclient[1135]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Jul 8 17:55:23 2022 daemon.err ovpnclient[1135]: OpenSSL: error:02001002:system library:fopen:No such file or directory
Fri Jul 8 17:55:23 2022 daemon.err ovpnclient[1135]: OpenSSL: error:2006D080:BIO routines:BIO_new_file:no such file
Fri Jul 8 17:55:23 2022 daemon.err ovpnclient[1135]: Cannot load CA certificate file ca.ipvanish.com.crt (no entries were read)
Fri Jul 8 17:55:23 2022 daemon.notice ovpnclient[1135]: Exiting due to fatal error```
