Hey, I bought a B1300 earlier this year. After last week, I just noticed that it’s only running normal Shadowsocks. Did a search in the apps for either SSR or simple-obfs plugin and couldn’t find any. I’m on the latest firmware.
Are there plans to add either simple-obfs plugin or SSR? If not, could someone point me to a guide as to how I can compile my own ipk for either one?
Dear @kyson-lok,
I got it for my Mango under “ramips”, thanks. Which directory should I go to for GL-AR750S-Ext ? Is the ipk file available for GL-AR750S-Ext ?
Hi @kyson-lok,
I am using the latest firmware of V3.025 of Slate (AR750s). I installed luci-app-shadowsocksR (1.2.1) from the >Plug ins. I set the parameters but it does not seems to run.
I used the firmware of V3.010 on Creta (AR750). The luci-app-shadowsocksR (1.2.1) also do not work.
I was running V3.012 firmware on Mango, and installed the luci-app-shadowsocksR (1.2.1) from the > Plug ins in the same manner, it runs beautifully. Looks like the cheaper products are better 8-(
Could the luci-app-shadowssocksR (1.2.1) on the Slate and Creta somehow corrupted?
Yes, for SSR Client, after reboot, I can find it in the "Running Status".
But for SSR Server, it never appear in the “Running Status”.
I am using firmware V3.025 on Slate for the above.
I tried firmware V3.026, it is even worse. I cannot login to 192.168.8.1 after I reboot.
You may want to try luci-app-shadowsocksR (1.2.1) on Slate in your lab and see if it works.
Hi @kyson-lok,
I found that you have re-made a new test firmware for AR750 and AR750s called 3.026-0729 (the previous version was 3.026-0727). I upgraded my AR750 and AR750s respectively. And this time luci-app-shadowsocksR (1.2.1) works after reboot for both AR750 and AR750s. And MT300N-V2 also works well under the new official release of 3.025. Thank you very much for continuous effort in upgrading the firmwares.
By the way, I found that the AR750 official release is still 3.010, very far behind AR750s official release of 3.025, is there an overlook somewhere?
