B1300 Beta 4.1.0 Version3
This version enables the simultaneous operation of an VPN server and client. But I can only connect to the OpenVPN server from the wan of the OpenVPN client is turned off. When I enable the OpenVPN client, the server is no longer connectable. The same happens when I run wireguard server & wg client together. Is this a problem with the beta firmware or do I need to change some settings?
Edit: From lan the VPN server remains connectable with running VPN client. But from WAN it is only connectable if VPN client is off.
