Using the same USB-3 stick with ExFAT file system that works fine in AR300M, I cannot discover the drive when attached to B1300. What might be the reason?
If I connect manually using IP and port 445, it works. Just that there is no hostname shown, only the IP.
The settings are the same (share via LAN).
I noticed B1300 has a much older version of the plugin kmod-usb-storage (4.4.60-1) than AR300M (4.9.120-1)…
