Fresh install of 3.218 on a B2200, I want to repeat another WiFi, dashboard states:
How do I disable mesh to enable repeater, I cannot find it in the web interface.
Ok, weird, I have repeater active, as I'm connected to the B2200 when I'm posting this, but the web interface is stating I have no internet.
So there's a bug in 3.218.
Please may the B2200 have a functional repeater mode.
Please may Goodcloud work in Repeater mode as the B2200 is claimed to be offline, but I'm posting this from it.
Can AGH be updated?
Can mesh be disabled in it's entirety, cannot do this from the Goodcloud or the GL dashboard, while I can from Luci I have no guarantees it will stay disabled after a reboot.
The repeater mode and the Internet from repeater is normal which tested in my router.
The platform remote to the router works ok as well.
Can try to disable the mesh:
/etc/init.d/gl_mesh stop
/etc/init.d/gl_mesh disable
ADH cannot be updated I assume, since I check the AGH only have one relative plugin in the list, may be a package integrating AGH+GUI.
If is necessary to update, may can try to uninstall AGH and then install the latest AGH from others repo and use on Luci.
