Need help as I cannot get my two Velica B220 Routers to Mesh. Confirm both are in Mesh Mode. When using the app, it fails to find the 2nd Velica to establish a mesh network. I’ve spent hours hitting the connect button over and over trying to get them to find each other.
Anyone any ideas or is there an alternative method to set up a mesh network through the cli or something?
One router is configured with the user.pass/LAN IP’s and Wireless networks etc. The other is without any setup, straight from a reset and I can find fine on my phone through the app/ble connection just fine.
Adding some logs
at May 7 19:34:21 2022 daemon.notice netifd: wan6 (16556): uci: Entry not found
Sat May 7 19:34:47 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 IEEE 802.11: authenticated
Sat May 7 19:34:47 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 IEEE 802.11: associated (aid 19)
Sat May 7 19:34:47 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: sending 1/4 msg of 4-Way Handshake
Sat May 7 19:34:47 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Sat May 7 19:34:48 2022 kern.err kernel: [67936.883611] wlan: [24687:I:ANY] FWLOG: [42132987]
Sat May 7 19:34:48 2022 kern.err kernel: [67936.883662] wlan: [24687:I:ANY] RATE: ChainMask 3, peer_mac e6:a7, phymode 5, ni_flags 0x00201006, vht_mcs_set 0x0000, ht_mcs_set 0xffff, l$
Sat May 7 19:34:48 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: sending 1/4 msg of 4-Way Handshake
Sat May 7 19:34:48 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Sat May 7 19:34:49 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: sending 1/4 msg of 4-Way Handshake
Sat May 7 19:34:49 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Sat May 7 19:34:50 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 IEEE 802.11: disassociated
Sat May 7 19:34:51 2022 daemon.notice netifd: wan6 (16556): uci: Entry not found
Sat May 7 19:35:23 2022 daemon.notice netifd: wan6 (16556): uci: Entry not found
Sat May 7 19:35:24 2022 daemon.info dnsmasq-dhcp[16759]: DHCPREQUEST(br-lan) 192.168.22.124 a4:77:33:72:b0:ba
Sat May 7 19:35:24 2022 daemon.info dnsmasq-dhcp[16759]: DHCPACK(br-lan) 192.168.22.124 a4:77:33:72:b0:ba Chromecast
Sat May 7 19:35:35 2022 authpriv.info dropbear[19472]: Child connection from 192.168.22.239:54500
Sat May 7 19:35:36 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 IEEE 802.11: authenticated
Sat May 7 19:35:36 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 IEEE 802.11: associated (aid 19)
Sat May 7 19:35:36 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: sending 1/4 msg of 4-Way Handshake
Sat May 7 19:35:36 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Sat May 7 19:35:36 2022 authpriv.notice dropbear[19472]: Pubkey auth succeeded for ‘root’ with key md5 fa:0e:c4:44:a6:c5:ca:40:c8:5a:b9:6a:22:29:21:a8 from 192.168.22.239:54500
Sat May 7 19:35:36 2022 kern.err kernel: [67984.860837] wlan: [24687:I:ANY] FWLOG: [42182807]
Sat May 7 19:35:36 2022 kern.err kernel: [67984.860887] wlan: [24687:I:ANY] RATE: ChainMask 3, peer_mac e6:a7, phymode 5, ni_flags 0x00201006, vht_mcs_set 0x0000, ht_mcs_set 0xffff, l$
Sat May 7 19:35:37 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: sending 1/4 msg of 4-Way Handshake
Sat May 7 19:35:37 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Sat May 7 19:35:38 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: sending 1/4 msg of 4-Way Handshake
Sat May 7 19:35:38 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Sat May 7 19:35:38 2022 daemon.info dnsmasq-dhcp[16759]: DHCPREQUEST(br-lan) 192.168.22.249 b8:27:eb:df:05:ad
Sat May 7 19:35:38 2022 daemon.info dnsmasq-dhcp[16759]: DHCPACK(br-lan) 192.168.22.249 b8:27:eb:df:05:ad pi-homebridge
Sat May 7 19:35:39 2022 daemon.info hostapd: ath0: STA 90:dd:5d:bc:e6:a7 IEEE 802.11: disassociated
