Just purchased a Slate AX. Have inserted a microSD card.
Would like the ability to backup my Samsung android phone to the microSD card every evening while traveling.
Any app or suggestions on how to do this would be appreciated.
MM
MM
Enable the Samba of the Network Storage, manual move your files to the network neighborhood folder in the Files Manager of the phone.
Can try one of these third-party plug-ins in the OpenWRT/Luci which support mutil-platform, not only the OpenWRT (Router as the files server), for automatically sync your files: Verysync, Syncthing, NextCloud
Thank you, Bruce. Will give it a try. This is all new so it seems like the early days of the PC. ![]()
