Bad Link Mode not working well
Two issues that are there when testing at a latency of about 190 ms
  1. The typing in comet kvm appears more erratic than in pi kvm. Example if you type “humor” - hum may appear suddenly together and then o, r
  2. The bad link mode in pikvm works well with no repeats but in comet kvm something is wrong - in some cases when you type “humor” you get “huuumooor” even if bad link mode is on. Yes if you keep a key pressed comet kvm shows it only once but in real conditions it doesn't work well
Tested both kvms at the same latency and using the latest beta release of PoE for comet.
This part of the code is exactly the same; it might just be a testing error.
Typing behavior in Comet KVM appears noticeably more erratic compared to PiKVM. For example, when typing the word “humor,” the characters “hum” may suddenly appear together, followed by “o” and then “r,” instead of being entered smoothly in sequence. While PiKVM’s bad link mode works reliably and prevents repeated keystrokes, the same mode on Comet KVM does not seem to function correctly. In some cases, typing “humor” may result in outputs like “huuumooor,” even when bad link mode is enabled. Although holding down a key on Comet KVM correctly registers it only once, the behavior during normal typing conditions remains inconsistent and problematic. Both KVM systems were tested under the same latency conditions, and the latest beta release of PoE was used for Comet during testing.
