Hey how to lock my Band on my New Spitz AX 5G. Device use every time band 3 but i want to Use Band 1 only. i hope i can do it with a AT Command. Thanks ![]()
I use O2 Germany
I use O2 Germany
Band Lock and associated profiles are set under “Internet” → “Manual Setup” → “Use Other Settings” → “Enable Band Filter”.
To create a profile that can be selected later, activate “Save Settings” and assign a name.
Thanks you very much That worked
