Band steering on GL-MT3000
I want to use same SSID (and password) for Wifi 2.4 GHz and 5 GHz.
To my knowledge "band steering" is the keyword here.
If I connect my Android mobile device to this SSID, and I'm located in the same room as the router, my mobile device shows 2.4 GHz connection.
Can you please advise how to fix this?
THX
There is no real band steering built-in.
The device will connect to whatever band it thinks brings better connection.
I'm running an AP with OpenWrt in the same room, 2 Wifi, 1 SSID.
Here the device selects 5 GHz first.
