I recently purchased the GL.iNet GL-MT3000 router and I must say, it is an excellent router. However, I am currently facing a problem with logging into a UBIQUITI hotel router. I have set up my GLINET router in client mode and have had no issues connecting to other networks.
Has anyone else faced a similar problem with UBIQUITI routers? If so, could you kindly share any solutions or workarounds that worked for you? I would greatly appreciate any advice or suggestions that could help me resolve this issue.
Remembering that it does NOT have a portal/login page
Directly login from the laptop it works normally
Thank you in advance for your support and assistance.
Do you know if hotel’s AP is broadcasting its SSID in 2.4Ghz, 5Ghz or both? Also are all of your VPN services turned OFF and your DNS set to automatic?
Just to make sure, it’s WPA PSK (just a password) and not WPA EAP (user and password)? The latter would connect fine with user and password on a laptop or iPhone, but IIRC from my recent research the Beryl does not support EAP.
If you did not do so DNS rebinding should be turned off as well as authoritative DNS in GUI DNS settings.
You will also want to turn off Adguardhome and use the hotels DNS for the initial setup.
