I would like to experiment with BATMAN-ADV to create a mesh network.
Are there any GL-iNet routers with mesh support pre-installed?
Which routers would you recommend?
Looking at the openvpn tutorial I noticed a mesh icon in the images you posted:
https://www.gl-inet.com/docs/openwrt/src/openvpn/1.jpg
What router is this and what mesh protocol it is using?
Hi, we had a mesh UI but not finished.
To use mesh, just insall batman-adv using opkg and you can configure, manually!
Will it work on any GL-iNet router?
BATMAN-Adv works for ath9k and ath10k driver, so it will work for AR150, MiFi, AR300M, AR750, Domino Core
Any insight on the mesh part of the webgui readiness?
I just ordered 2 AR150 routers and I’ll do some experimenting when they arrive and report back.
@Jose_Leal, I can send you a firmware with BATMAN but I still don’t know how the UI will go. It is really not easy to design a good UI.
Hi Alzhao, are you able to send me the firmware with BATMAN installed? I have been struggling to get this up and running manually on the AR300M-Lite (despite it being supposidly simple).
I only have firmware for AR150. It will need a little time tocompile for AR300M.
I don’t have time this week. I bookmarked this post
Mesh networking support in Openwrt/LEDE is growing rapidly and there are alternatives to Batman available for experimenting.
However if you have a specific requirement for a plug and play working mesh then we have firmware available for purchase for any model AR300M (and pre flashed hardware if required).
@Alzhao - did you get BATMAN working on AR300M-lite?
sorry I never got a time to compile BATMAN firmware.
Sorry for that.
Hello, @alzhao.
I have bought a couple of AR-150 units to start trying to build a mesh. Would you tell me how can I get the firmware with B.A.T.M.A.N. installed, please?
Thank you.
when you build the firmware, just choose batman-adv and compile it in the kernel.
I have the mesh firmware uploaded to here GL.iNet download center
I haven’t touch it for a long time. So cannot give exact guide. You should use the switch button to control the mesh status, left: root node, right: leaf node
Ok, thank you, I will try (first time with this stuff).
I’m a little lost about building firmware, do you know any documentation (for newbies) I can read to begin?
Thank you.
The readme there will get you started. If you don’t want to brick your only device I suggest not doing it or having a spare to mess with.
openwrt is a complicated project to build correctly for a device. there is no checking to see if what you selected will actually make your device run, so chances are high that it won’t.
